CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
733
Beginner
SG250X UDLD support
Do you know if Cisco plan to support UDLD on futurre software releases for SMB 250 switches ?
Or Is there any hardware limitation regarding this feature ?
3 REPLIES 3
Highlighted
VIP Collaborator
Re: SG250X UDLD support
 - It seems to be supported according to the 'Applicable Devices' list from the link below ; anyway could you check the configuration menu(s) as explained and check whether the required setting(s) are available ?
            https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-250-series-smart-switches/smb5798-configure-the-udld-settings-on-a-switch.html
 M.
Highlighted
Beginner
Actually no, the settings are not available in web UI.
Also not in CLI . On this side command reference https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/250_/2_4_5/cli_guide/cli_sx250_2_4_5.pdf
Cisco Sx250 Ph. 2.4.5 Devices - Command Line Interface Reference Guide
Cisco Sx250 Ph. 2.4.5 Devices - Command Line Interface Reference Guide CLI GUIDE
www.cisco.com
does not mention udld.
Also data sheet for 250s does not list UDLD as a supported protocol, whille other series (ie 350) datasheets do list UDLD.
Highlighted
VIP Collaborator
 - If it's not advertised as being supported in the data sheet ; you will not see it becoming available in subsequent software releases , because then it usually also relates to hardware limitations.
  M.
