CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
142
patrick.hurley
Participant
SG300-10 Initial Setup Question
I changed my login id and password from the default of cisco/cisco but it only asked me to change the password, not the username and I cannot get back in because cisco as the username does not work and neither does root or admin.  What is the username set to after changing the password for the first time?
2 REPLIES 2
balaji.bandi
VIP Guru
if not changed the username it should be cisco and a new password.
reload the device and test it.
if you like to reset to factory again :
With the power on, press-and-hold the Reset button for more than 10 seconds.
BB
Thanks!
