02-21-2014 11:56 AM
Hello
I just upgrade my SG300 to the latest firrmware 1.3.7.1.8 and I have encountered this issue:
- By default, the VLAN interface was Enabled but the display is always Disabled
- I can not change it and I cannot ping the VLAN IP interface as well (I gave it an IP 192.168.10.1)
Is this a bug? Does any one know how to fix this issue? Please help me!
Greatly appreciate your help
Minh
Solved! Go to Solution.
02-21-2014 12:27 PM
minh06,
Did you upgrade the boot code to Sx300_FW_Boot_1.3.5.58?
- Marty
02-21-2014 01:19 PM
Here's an article I found to be helpful...
http://cmc.site11.com/2014/01/how-to-upgrade-firmware-and-boot-image-on-cisco-sg300-switch/
02-21-2014 01:58 PM
Minh,
1) Download Sx300_FW_Boot_1.3.5.58.zip
2) Extract the zip file and you will see sx300_boot-13506.rfb
3) In the switch, browse to Administration-> Upgrade/Backup Firmware
4) Select via TFTP, Upgrade and Boot Code
5) Enter the IP address of the TFTP server and file name: sx300_boot-13506.rfb
- Marty
02-21-2014 12:27 PM
minh06,
- Marty
02-21-2014 12:36 PM
Thanks Marty
This is what I used:
sx300_fw_1.3.7.18.ros
I boot into that image making it acrive
what is Sx300_FW_Boot_1.3.5.58? is it a new version?
Minh
02-21-2014 12:50 PM
Minh,
When the switch is upgraded to Release 1.3.5.58, the boot code must be upgraded as well. Did you upgrade to
sx300_fw_1.3.7.18 from an earlier version?
You can download 1.3.5.58 from the link. Extract the file and you will see a boot code file along with the .ros file. You need to use a TFTP server to install the boot code.
- Marty
02-21-2014 01:40 PM
Hi Marty, great thanks
I see what I have missed.
Problem is I did not see the boot code file from the URL you gave
I only see the ros file.
It strange. The article also point to that site for the zip file. I have seen no zip as well
Minh
02-21-2014 01:58 PM
Minh,
- Marty
02-21-2014 03:20 PM
02-21-2014 03:53 PM
Minh,
Is anything connected to VLAN 10 or VLAN 20 on the switch? The interface will be disabled if there is no connection.
- Marty
02-22-2014 01:05 AM
Hi Marty
Thanks! Thanks! Thanks!
It works!!!!!
Minh
02-23-2014 08:16 AM
Hi Marty
Sorry to bother you again
I was running SG300 with the release 1.3.5.58
Change system mode to layer 3
Access the switch via Seial interface.
The "menu" command is not regcognized any more
Cisco#menu
Unregconized command
I was panic! Not possible to do anything any more!
Could you please give me some hint?
Minh
02-23-2014 12:11 PM
02-23-2014 12:20 PM
Thanks Marty
I find out 2 commands that helped:
show system mode
set system mode
after I set system mofe to router, I used
show ip interface to find out the current ip address amd use it to access the Web-based GUI
Is it a bug in the latest versio and version 1.3.5.58 that the menu command just diesappear?
I still have it in older version 1.1.2
Thanks Marty
Minh
07-18-2014 02:25 PM
Thank you .. you made my day ... i was trying to assign Ip to newly created vlan interface but every time it gets stuck when i try to do so .. i upgraded firmware and was banging my head .. later saw ur post to upgrade boot code ...
thank you again..
02-21-2014 01:19 PM
02-23-2014 12:20 PM
Thanks Clint. That help
