04-23-2015 02:00 PM
I can't get working DHCP server on SG300 (layer 2) on interfaces set as "Private VLAN - Host".
I described my setup here. Everything works well except assigning addresses on ports with secondary VLANs
here is my setup:
VLANs:
vlan database vlan 2,20,200 exit interface vlan 200 private-vlan primary exit interface range vlan 2,vlan20 private-vlan community exit
DHCP server:
ip dhcp server ip dhcp excluded-address 192.168.1.100 192.168.1.100 ip dhcp pool network Pool1 address low 192.168.1.1 high 192.168.1.254 255.255.255.0 lease 8 domain-name local default-router 192.168.1.128 dns-server 192.168.1.128 exit
other settings:
ip domain name local ip name-server 192.168.1.128 8.8.8.8 ! interface vlan 2 name SURVEILLANCE ! interface vlan 20 name CLIENTS ! interface vlan 200 name PRIMARY ip address 192.168.1.100 255.255.255.0 no ip address dhcp private-vlan association add 2,20 !
interfaces:
GE5 - to router
interface gigabitethernet5 switchport mode private-vlan promiscuous switchport private-vlan mapping 200 add 2 !
GE13 - to client PC (for testing)
interface gigabitethernet13 switchport mode access switchport access vlan 200 !
GE17 - to IP camera
interface gigabitethernet17 switchport mode private-vlan host switchport private-vlan host-association 200 2 !
GE18 - to client PC
interface gigabitethernet18 switchport mode private-vlan host switchport private-vlan host-association 200 20 !
GE26 - to server (recoder and file server)
interface gigabitethernet26 switchport mode private-vlan promiscuous switchport private-vlan mapping 200 add 2,20 ! exit
other settings:
ip default-gateway 192.168.1.128
I can communicate from GE13, GE18 to GE5 and GE26
I can communicate from GE26, GE5 to GE13, GE17, GE18
Clients on GE5, GE13 and GE26 obtains an IP address correctly.
Clients on GE17 and GE18 can't obtain an IP address.
Summary:
Hosts connected to access mode ports (untagged VLAN 200) can cooperate with DHCP;
Hosts connected to private-vlan promiscuous mode ports can cooperate with DHCP;
Hosts connected to private-vlan host mode ports cannot cooperate with DHCP
Can anyone help me with this setup?
04-23-2015 03:10 PM
I'm sorry you are having issues configuring the device.
The first and main question that I can ask is if your switch is definitely on Layer 2 or not.
If it is on Layer 2 then you will be able to enter the configuration fro the DHCP server but it will not work, the only way for the switch to be able to hand out IP address is to be on layer 3.
Please confirm and let us know.
If you need to change it to layer 3, please keep in mind that when you do so, the switch will factory reste and you will have to configure everything from scratch.
04-24-2015 09:57 AM
Hello, thank you for the answer.
Yes, the switch is on Layer 2 (as I mentioned above).
But the DHCP server is working in Layer 2 on my switch. It assigns addresses correctly in regular VANs al well as in Primary VLANs. The only problem is with community VLANs.
04-24-2015 12:50 PM
I'm sorry, I'm afraid I'm not following.
The switch has the DHCP options still available on layer 2 and, if configured, it can provide IP addresses for the VLAN which the management IP address is on. Besides that, the switch, by itself, won't be able to assign IP addresses to any other VLAN because it wouldn't know what VLAN is supposed to receive what IP address even if the pools are configured.
Maybe we are missing some more network information, for example the Topology, also I didn't see any information for any other address pool on the info you sent.
I may not be understanding your issue or your configuration correctly, so, more information will definitely help.
04-25-2015 08:37 AM
Here is my setup:
You can read what I did here: LINK (second post). I think, I don't need additional pools.
I think the problem is that DHCP server (which is on the switch) can't assign IP addresses to community VLANs because although it is on the VLAN 200, but it isn't member of Primary VLAN.
Am I right?
If yes, if I create additional promiscuous port with primary VLAN 200 and connect an external DHCP server to it, I should be able to obtain IP addresses on clients in community VLAN.
04-27-2015 11:30 AM
As I understand DHCP server is only supported in L3 mode. I think changing the switch to L3 will solve this issue for you and allow you to create a pool on VLAN 200 (or others if you wish). You can also have an external DHCP server anywhere that is routable and use the DHCP relay feature. Here is a post about it that should help if you want to go that route: http://community.spiceworks.com/topic/444029-cisco-switch-in-l3-mode-enable-ip-helper-for-dhcp
05-01-2015 03:12 AM
The DHCP server on SG300 works fine in layer 2 mode, except that it doesn't work in Private VLAN in L2.
It looks like services on the switch work only in regular VLAN and there is no possibility to force them to act in Private VALNs (or I can't set up it properly).
I connected an external DHCP server (to the promiscuous port) for testing purposes and it works as I expected: the external DHCP server assigns addresses to all private VLANs: a Primary VLAN as well as a Community VLAN.
