07-09-2014 12:16 PM
i just got a SG300-10, and i tried updating the firmware and the bootloader.
now im stuck with this:
SW version 1.3.7.18 ( date 12-Jan-2014 time 18:02:59 )
Boot version 1.1.0.6 ( date 11-May-2011 time 18:31:00 )
HW version V02
i tried to update it via the webinterface and CLI booth without any changes.
these are the ressources i used while upgrading:
https://supportforums.cisco.com/discussion/11953536/sg300-bootloader-upgrade
http://columbiabrian.blogspot.ch/2014/04/how-to-upgrade-firmware-on-cisco-small.html
any input is welcome :)
Solved! Go to Solution.
07-09-2014 05:48 PM
There is currently a problem with the bootcode files available on the website. I just went and tried to download the bootcode and it tried to tell me it was some 30 MB file. The appropriate people have been notified, and the problem should be corrected soon.
In the meantime I have attached the correct bootcode to my post, feel free to use that.
Hope that helps, and sorry for the inconvenience,
Christopher Ebert - Advanced Network Support Engineer
Cisco Small Business Support Center
*please rate helpful posts*
07-09-2014 05:48 PM
07-10-2014 04:46 AM
Hi Chrebert,
Thanks for the reply, i did the same procedure with the file you uploaded.
and now it works!
strangely enough i had the same file size.
anyway its working now.
cheers
11-12-2014 04:04 AM
Hi Chrebert,
I was struggling to update the boot code on my SG300-10 until I came across your post.
Your attached boot code worked for me
10-07-2014 06:53 PM
What am I doing wrong? The file loads in to the switch, then I reboot. Nothing. Same boot loader version.
Help anybody.
08-27-2018 08:09 AM
