SG300 Firmware Upgrade - Copy: Illegal software format
jclarke99
Following the process documented in the SG300 manual - When I select the firmware source file - Select File sx300_fw-14088.ros (I just downloaded from the Cisco website)  -  I receive the following error - Copy: Illegal software format.  What is the file extension of the firmware upgrade file?  What am I doing wrong?
48 Replies 48
V K Moorthy
 Kindly upgrade the boot loader first before attempting the firmware. Boot loader (.rfb file)can be found on the same zip folder as the firmware.
regards
Moorthy
Even after updating the boot loader, i am getting the same error message "Illegal Software format"
Gaurav
Hi All,
Im having the same problem.. Anyone had news on this?
Matt
Hi All,
I've sorted this... You need to carry out an interim firmware upgrade to the previous version. Then upgrade to 1.4.X.X. The switch flash file system was changed in 1.3.7.18
Hope it helps?
Matt
thanks, just had the very same problem and you tip did it :)
Thanks, Adam
My pleasure..
Please rate all useful posts :)
Matt
Chaps
does any one know were can download the the interim flash software.
unless im looking in the wrong place i dont see the version you guys mention.
You need to expand the file tree as follows..
All the best
Matt
Hello Cisco Support Community,
Wanted to add to this thread. I recently obtained a SG 300-10 in which I had to upgrade its firmware before I could proceed with my configurations. Thanks to your comments and tips I was able to upgrade our SG 300-10 from firmware v1.0.0.27 to 1.4. 5.02. Here is what I did...
Step 1: upgrade "boot code" first to "sx300_boot-13506.rfb"
Step 2: upgrade firmware to "sx300_fw_1.3.7.18.ros"
Step 3: "Reboot"
Step 4: upgrade to firmware "sx300_fw-1413.ros"
Step 5: "Reboot"
Step 6: Upgrade to firmware "sx300_fw-14502.ros"
Step 7: "Reboot"
The reason why I updated from 1.3.7.18 to 1.4.1.3 is because of my experience with jumping through major versions. I did not find any information regarding a specific firmware level stop point to update from 1.3.7.18 to 1.4.5.02, but you can sure try to update all the way to 1.4.5.02. Please document here your experience by jumping straight to the latest version.
My 7 steps did the job for our SG 300-10.
Thank you,
Gustavo
Gustavo,
I was able to skip step 4 (and 5) and upgrade directly from "sx300_fw_1.3.7.18.ros" to "sx300_fw-14502.ros".
Thank you for detailing these steps.
  Paul Lemaire
Hello
I bought a sg-300-52p or-switch and it has a vero firmware SW version 1.3.0.62 and Boot version 1.1.0.6, I do not find a version 1.3.5, I'm a doubt, I can go straight to the version 1.4.7?
thank you
Dear
I found the version .rfb 1.3.5 inside the .zip of version 1.4.1
Thank you
instala la versión, 1.3.7.18 y luego podrás actualizar a la actualización que necesitas
https://software.cisco.com/download/home/283019611/type/282463181/release/1.3.7.18
Gustavo,
I wasn't able to update the boot code.(rfb), i keep having the "Illegal Software format" error. Although I was able to update the system to the 1.3.7.18 version, but i could not get any further, because after reboot, the firmware version wasn't active, later after that, if i tried with a higher firmware version, i got: "oversized file" and the upload of the firmware was cancelled at 96%.
Thank you,
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
