01-22-2022 01:46 PM - edited 01-23-2022 04:55 AM
Hi, I am a novice when it comes to VLAN's and have setup a test environment to learn. I would like to figure out how to get VLAN hosts to communicate with other VLAN hosts. IE.. VLAN 10 host communicate with VLAN20 host.
Cisco RV345P - 10.68.1.1
SG300-28PP (Layer 3)
VLAN1 - 10.68.1.2 (default) - Port 1 - Access mode to router - Untagged
VLAN2 - 10.68.10.1 - Port 3 & 15 - Trunk - Untagged
VLAN3 - 10.68.20.1 - Port 4 - Trunk - Untagged
VLAN4 - 10.68.30.1 - Port 5 - Trunk - Untagged
VLAN5 - 10.68.40.1 - Port 6 - Trunk - Untagged
All VLAN hosts Can reach the internet.
All VLAN hosts Can ping other hosts within the same VLAN.
All VLAN hosts Can Ping the gateway of other VLAN's.
However...
VLAN hosts cannot ping hosts on other VLAN's. (Time out response)
I get the same results when pinging from the switch interface and selecting the different source IP's for each VLAN.
SG300 Config:
config-file-header csg300l3 v1.4.11.5 / R800_NIK_1_4_220_026 CLI v1.0 set system mode router file SSD indicator plaintext @ vlan database vlan 10,20,30,40 exit voice vlan oui-table add 0001e3 Siemens_AG_phone________ voice vlan oui-table add 00036b Cisco_phone_____________ voice vlan oui-table add 00096e Avaya___________________ voice vlan oui-table add 000fe2 H3C_Aolynk______________ voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone voice vlan oui-table add 00d01e Pingtel_phone___________ voice vlan oui-table add 00e075 Polycom/Veritel_phone___ voice vlan oui-table add 00e0bb 3Com_phone______________ ip dhcp server ip dhcp pool network IoT address low 10.68.40.50 high 10.68.40.65 255.255.255.0 dns-server 10.68.1.1 exit ip dhcp pool network LAN address low 10.68.10.50 high 10.68.10.99 255.255.255.0 dns-server 10.68.1.1 exit ip dhcp pool network CCTV address low 10.68.30.50 high 10.68.30.65 255.255.255.0 dns-server 10.68.1.1 exit ip dhcp pool network WLAN address low 10.68.20.50 high 10.68.20.99 255.255.255.0 dns-server 10.68.1.1 exit bonjour interface range vlan 1 hostname csg300l3 line console exec-timeout 0 exit line ssh exec-timeout 0 exit line telnet exec-timeout 0 exit username password encrypted privilege 15 ip http timeout-policy 0 ip name-server 10.68.1.1 8.8.8.8 8.8.4.4 ip domain polling-interval 8 ! interface vlan 1 ip address 10.68.1.2 255.255.255.0 no ip address dhcp ! interface vlan 10 name LAN ip address 10.68.10.1 255.255.255.0 ! interface vlan 20 name WLAN ip address 10.68.20.1 255.255.255.0 ! interface vlan 30 name CCTV ip address 10.68.30.1 255.255.255.0 ! interface vlan 40 name IoT ip address 10.68.40.1 255.255.255.0 ! interface gigabitethernet1 switchport mode access ! interface gigabitethernet3 switchport trunk native vlan 10 switchport forbidden default-vlan ! interface gigabitethernet4 switchport trunk native vlan 20 switchport forbidden default-vlan ! interface gigabitethernet5 switchport trunk native vlan 30 switchport forbidden default-vlan ! interface gigabitethernet6 switchport trunk native vlan 40 switchport forbidden default-vlan ! interface gigabitethernet15 switchport trunk native vlan 10 switchport forbidden default-vlan ! exit ip default-gateway 10.68.1.1 ip ssh-client key rsa key-pair
Any help is appreciated.
Thank you.
Solved! Go to Solution.
01-24-2022 07:37 PM - edited 01-24-2022 08:02 PM
Well, it turns out the issue was not with my switch configuration at all. The windows firewall on my devices were blocking traffic from other subnets. Should have tested with a device other than a computer.
Just need to look into making rules in the windows firewall to allow the traffic.
Edit: If anyone is looking for how to allow other subnets through the windows firewall, this link is very useful.
windowsreport.com/windows-firewall-allow-ip-range
01-23-2022 06:47 AM
"show ip route" output - 1 laptop connected to VLAN10 and one desktop connected to VLAN20.
IP Forwarding is enabled, I cant figure out why I cannot ping between these devices.
csg300l3#show ip route Maximum Parallel Paths: 1 (1 after reset) IP Forwarding: enabled Codes: > - best, C - connected, S - static S 0.0.0.0/0 [1/1] via 10.68.1.1, 28:43:24, vlan 1 C 10.68.1.0/24 is directly connected, vlan 1 C 10.68.10.0/24 is directly connected, vlan 10 C 10.68.20.0/24 is directly connected, vlan 20
01-24-2022 03:03 PM
Yesterday I reset the SG300 to factory defaults and set it back up from scratch.
Still the same result, devices can ping the gateway of each vlan but cannot ping devices on other vlans. Ip routing and forwarding enabled.
No ACL or policy in place.
I know I am missing something but I can't figure out what.
Devices connected to vlan 1 (default) show the router, 10.68.1.1 as the gateway instead of the switch ip 10.68.1.2.
Not sure if this is an issue.
Thank you in advance.
