CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
564
fmarshall
Beginner
SG300 password is "stuck"?
I have an SG300 with a lost password.
I want to change the password and to preserve the configuration so I can save the configuration with the new password.
I've used the console / power-on process to reset passwords just fine with other units.
With this one, even if I set it back to factory defaults, it appears that the console / power-on reset process doesn't work.
When I select (3) and then Enter, the menu with (3) reappears.
So that's a command LOOP.
6 REPLIES 6
balaji.bandi
VIP Guru
check what firmware compare to others working vs not working. Looks complete reset required i guess here?
BB
the firmware is the latest as we're going through an update check and installations....
sure that is one of the option you can upgrade to latest and test it. (but as you mentioned when ever you select option the process iterating or rebooting ? - hope not the same case with upgrade)
if that is the case may required to open SMB TAC case.
BB
Sujoy Paria
I hope you will get an option to press the ‘Esc’ button once the menu reappears. Please check the step 3 and 4 on the below mentioned link once and try that if that helps:
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-300-series-managed-switches/smb4985-administrator-password-recovery-for-300-and-500-series-manag.html
If those two steps works fine, then you can follow the remaining steps mentioned on that link to complete the process.
fmarshall
Beginner
Gee, I'm sorry, I thought my inital problem description covered that process AND says that it is what's not working.  It gets into an endless loop.
Create
Recognize Your Peers
Polls
How would you describe your level of technical expertise?
