CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
504
patrick.hurley
Participant
SG300 Private VLAN
I have never played with Private VLANs.   I have an SG300.  All ports are in VLAN 1.   The switch is connected to the inside interface of my ASA5505.  I have a work laptop and it seems that the IP addresses from my work VPN are showing up as inside my firewall when I go to the dashboard.  I'd like to put the laptop in an isolated vlan and give it access to the Internet and the printer.  Are there any examples on how to do that for the SG300 series switches?
3 REPLIES 3
mihail_ip
Beginner
Hello Patrick,
Do you have access to ASA5505 or in other words can you configure it?
Mike
Yes
Deepak Kumar
VIP Advocate
Check this guide:
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-300-series-managed-switches/smb5659-configure-private-vlan-membership-settings-on-a-switch-throu.html
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
