SG300 ssh strange error: "A client is already connected"
Tilman Schmidt
I've  got a few SG300-52 switches running software version  1.3.0.62 which I configured for ssh management access with public key  authentication via:
ip ssh server
ip ssh pubkey-auth auto-login
username mgmt password ... privilege 15
crypto key pubkey-chain ssh
user-key mgmt rsa
key-string ...
This is working fine if I connect interactively from my management system with:
ssh -i mgmt_id_rsa mgmt@switch
where mgmt_id_rsa is the name of a file containing the private key.
I get a privileged command prompt as intended, without being asked for a password.
However if I try to pass a command on the ssh command line like this:
ssh -i mgmt_id_rsa mgmt@switch show version
the command just hangs until I hit the Enter key a second time, and then emits the strange message:
Received disconnect from 10.11.12.13: 2:
(Exactly like that, including the line break after the "2:" and the blank before "A client".)
The same happens if I pipe the command I want to send into ssh like this:
echo show version | ssh -i mgmt_id_rsa mgmt@switch
except the error message appears immediately and I don't have to hit Enter a second time.
This is unfortunate as the objective of the whole exercise is to send commands to the switch from a script.
Can anyone shed some light on why this is so? What is that strange message "a client is already connected" trying to tell me? Is that another bug in Cisco's ssh implementation? Ideas for a workaround, anyone?
Tilman
PS: I already asked that question over in the "big business" support community before noticing there's a separate small business section, but got no answer there.
PPS: The real objective of the exercise is to make scripted backups and updates of the switches' configurations, ie. what would be naturally expressed as
scp -i mgmt_id_rsa mgmt@switch:running-config /var/backup/switch.config
and
scp -i mgmt_id_rsa /var/conf/switch.configchange mgmt@switch:running-config
except it doesn't work that way because the SG300's ssh server lacks scp support. Trying to replace that by
ssh -i mgmt_id_rsa mgmt@switch copy running-config scp://server/var/backup/switch.config
and
ssh -i mgmt_id_rsa mgmt@switch copy scp://server/var/conf/switch.configchange running-config
led me straight to the problem above. Just in case someone feels inclined to ask the standard forum question: "Why do you want that anyway?" :-)
Tilman Schmidt
Hi all,
I am now using the Unix/Linux tool "expect" as a workaround, with the following script I cobbled together from various suggestions on the 'net:
#!/usr/bin/expect
# Script to run an IOS command on a Cisco Small Business Switch via ssh
# Prerequisites:
# - Cisco Sx300 series switch with software version 1.3 or later
# - public key authentication with auto-logon configured
# Usage:
#   ciscosb-exec
# Args:
#         name or IP address of switch
#      command string to execute
# Result:
#   Switch response will appear on stdout
log_user 0
# configurable values
set userid "confmgmt"
set keyfile "$env(HOME)/.ssh/confmgmt_id_rsa"
set sshcmd "/usr/bin/ssh -c aes192-cbc"
set timeout 20
# end of configurable values
# below matches prompts such as "switch#", "switch>", "switch$"
set prompt "\[>#$\]\ *$"
set device  [lindex $argv 0]
set command [lindex $argv 1]
eval "spawn $sshcmd -l $userid -i $keyfile $device"
match_max [expr 32 * 1024]
while { 1 } {
  expect {
    # command prompt
    -nocase -re "$prompt"     {break}
    # confirmations (unknown fingerprint etc.)
    -nocase -re "\\(yes/no\\)"  {send "yes\r"}
    # username prompt
    -nocase -re "name:|^login:" {send "$userid\r"}
    # password prompt
    -nocase -re "word:"       {puts "Public key authentication failed";exit}
    # errors
    eof                       {puts "Connect failed: $expect_out(buffer)";exit}
    timeout                   {puts "Timeout waiting for command prompt"; exit}
send "terminal datadump\r"
expect {
    -nocase -re "$prompt"     {send "$command\r"}
    eof                       {puts "Connection lost: $expect_out(buffer)";exit}
# actual command may take a long time
set timeout 120
expect {
    # skip command echo
    -re "$command\[\r\n\]*"   {exp_continue}
    # answer confirmation request
    -nocase -re " \\(Y/N\\).*\? *$" {
        # send confirmation, skip echo
        send "Y"
        expect -re "Y\[\r\n\]*"
        exp_continue
    # collect response, excluding next prompt
    -nocase -re "(.*)\r\n.*$prompt" {set output $expect_out(1,string)}
puts "$output"
send "exit\r"
expect eof
Saved as an executable file named ciscosb-exec somewhere in $PATH, so far it seems to be working reasonably well for usages such as
ciscosb-exec myswitch "copy scp://myserver/workdir/myswitch.configchange running-config"
ciscosb-exec myswitch "copy running-config startup-config"
ciscosb-exec myswitch "copy startup-config scp://myserver/configdir/myswitch.config"
ciscosb-exec myswitch "show interfaces status detailed"
Hope it helps someone.
Tilman
12 Replies 12
Tom Watts
Hi Tillman, please look in to the SCP options of this switch.
Chapter 19 of the admin guide
http://www.cisco.com/en/US/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/78-19308-01.pdf
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hi Tom,
thanks for answering.
I read chapters 19 (SSH client) and 20 (SSH server) of the admin guide but didn't find anything that looked as if it might help solving the problem I described.
Could you be more specific?
Tilman
Hi Tilman, I think a ssh session is establishing or has been established and it did not clear or was cancelled in the process of. I think it may be identifying a matching IP but potentially not a matching key or the matching key is in use or has already stored in to the table and is not available (at the time to be used).
Since you're using the specific keys, I feel like it hasn't "released" vs a "normal SSH" where the switch generates the keys each time.
-Tom
Hi Tom,
I analyzed this a bit further on the client side with the ssh debug option (-vv), and this is what happens from the client point of view:
The key exchange is no different between an interactive session and one passing a command on the command line, so it doesn't look like a key exchange or session establishment issue. I'm omitting that (lengthy) part below.
After that, in the case of a command passed on the command line, ssh -vv reports:
debug1: Entering interactive session.
debug2: callback start
debug2: client_session2_setup: id 0
debug1: Sending environment.
debug1: Sending command: show version
debug2: channel 0: request exec confirm 0
debug2: callback done
debug2: channel 0: open confirm rwindow 256 rmax 128
At this point, the output stops. Anything I type is just echoed until I hit Enter, then the ssh client emits:
Received disconnect from 10.11.11.41: 2:
and terminates without further debugging output.
In the case of an interactive session, the corresponding output is:
debug2: channel 0: request pty-req confirm 0
debug2: channel 0: request shell confirm 0
debug2: fd 3 setting TCP_NODELAY
followed by four newlines and the command prompt from the switch. Everything I type is then immediately interpreted by the switch, for example typing a question mark brings up the completion list. Nor does ctrl/C kill the ssh client; it's probably sent to the switch which ignores it.
The two differences I see are the additional "request pty-req" in the interactive case, and the command line case using "request exec" instead of "request shell". To elliminate the first one I added the -t (force pty allocation) option to ssh, which did indeed change the behaviour slightly to:
show version
The "request pty-req" is now there, and the command passed on the ssh command line is echoed, but not executed. What's more, keyboard input has no effect anymore, ie. it's neither echoed, nor does hitting Enter or ctrl/C have any effect. I can terminate the session by typing the ssh client escape sequence "~." though.
In comparison, if I do the same with another Linux machine as SSH server instead of the switch (either with or without the -t option), the result is:
debug2: channel 0: open confirm rwindow 0 rmax 32768
debug2: channel 0: rcvd adjust 131072
bash: show: command not found
debug1: client_input_channel_req: channel 0 rtype exit-status reply 0
debug2: channel 0: rcvd eof
debug2: channel 0: output open -> drain
debug2: channel 0: obuf empty
debug2: channel 0: close_write
debug2: channel 0: output drain -> closed
debug2: channel 0: rcvd close
debug2: channel 0: close_read
debug2: channel 0: input open -> closed
debug2: channel 0: almost dead
debug2: channel 0: gc: notify user
debug2: channel 0: gc: user detached
debug2: channel 0: send close
debug2: channel 0: is dead
debug2: channel 0: garbage collecting
debug1: channel 0: free: client-session, nchannels 1
Connection to arche closed.
("show: command not found" being of course the expected output from sending "show version" to a Linux host.)
The alternative, piping the command into ssh, does use "request shell" like the interactive case but fails anyway. Here's the debug log of that case:
debug2: channel 0: read<=0 rfd 4 len 0
debug2: channel 0: read failed
debug2: channel 0: input open -> drain
debug2: channel 0: ibuf empty
debug2: channel 0: send eof
debug2: channel 0: input drain -> closed
Again, no "rcvd adjust" after the "open confirm".
Nothing in all this changes if I have a second interactive  SSH session open in parallel on the same switch from the same client  machine, so it doesn't look like a session limit issue. The log messages from the switch (%AAA-I-CONNECT and %AAA-I-DISCONNECT) look identical for all the test cases above.
Any further ideas?
Tilman
Anyone?
Hi Tilman, I think it is an interesting observation you've made. I think this particular scenario would need a further looking in to.
Please contact the small business support center to create a service request.
-Tom
Hi Tom,
alas, the support center found my observation much less interesting than you did. This may be related to the fact that I don't have active support contracts for the switches in question. So this avenue seems barred.
Meanwhile, I have googled some more on the topic and it looks like nobody but me even expects SSH Exec to work. The common solution for sending commands to Cisco gear from a script via SSH is the same one as in good old Telnet times: using the expect tool to fake an interactive dialog so that the device never notices it isn't talking to a human operator. So I followed that path too, and came up with an expect script I called ciscosb-exec which allows me to run a command on a switch like this
ciscosb-exec myswitch "copy running-config scp://server/var/backup/myswitch.config"
If the posting function of this forum works again I'll try to post the script too so it might help others.
Thanks for your suggestions along the way.
Tilman
Tilman Schmidt
Hi all,
#!/usr/bin/expect
# Prerequisites:
# Usage:
#   ciscosb-exec
# Args:
# Result:
log_user 0
set timeout 20
while { 1 } {
  expect {
    # command prompt
    # username prompt
    # password prompt
    # errors
expect {
set timeout 120
expect {
    # skip command echo
        send "Y"
        exp_continue
puts "$output"
send "exit\r"
expect eof
Tilman
Tilman, thanks for the post. That is good info.
-Tom
Tilman Schmidt
Hi all,
I've improved my expect script a bit to:
  • allow specifying the SSH user and keyfile on the command line
  • allow sending configuration mode commands
  • correctly handle very long commands (line wrap) and commands producing no output
Extended usage:
ciscosb-exec confuser@myswitch -i ~/.ssh/confuser_id_rsa -c "ip ssh-client username memyself"
ciscosb-exec confuser@myswitch -i ~/.ssh/confuser_id_rsa "copy scp://myserver/workdir/myswitch.configchange running-config"
The "new and improved" script:
#!/usr/bin/expect
# Prerequisites:
# Usage:
#   ciscosb-exec [] [@]
# Args:
#         username on switch
# Options:
#   -c          execute in configuration mode
#   -i use SSH private key from
#   -d          activate debugging output
# Result:
# debug switches
log_user 0
exp_internal 0
# getopt implementation snarfed from http://www2.tcl.tk/17342
proc getopt {_argv name {_var ""} {default ""}} {
    upvar 1 $_argv argv $_var var
    set pos [lsearch -regexp $argv ^$name]
    if {$pos>=0} {
        set to $pos
        if {$_var ne ""} {
            set var [lindex $argv [incr to]]
        set argv [lreplace $argv $pos $to]
        return 1
    } else {
        if {[llength [info level 0]] == 5} {set var $default}
        return 0
# parse command line
set configmode [getopt argv -c]
getopt argv -i idfile
if {[getopt argv -d]} {
  log_user 1
  exp_internal 1
if {[llength $argv] != 2} {
  send_user "Usage: ciscosb-exec \[\] \[@\] \"\"\n"
  send_user "Arguments:\n"
  send_user "        target username (default: current user)\n"
  send_user "          target host name or IP address\n"
  send_user "         command string to execute\n"
  send_user "Options:\n"
  send_user "    -c            execute in configuration mode\n"
  send_user "    -i    use SSH private key from \n"
  send_user "    -d            activate debugging output\n"
  exit 1
set target [split [lindex $argv 0] @]
if {[llength $target] == 1} {
  set device [lindex $target 0]
  set userid "$env(USER)"
} elseif {[llength $target] == 2} {
  set userid [lindex $target 0]
  set device [lindex $target 1]
} else {
  send_user "bad target: [lindex $argv 0]\n"
  exit 1
if {[info exists idfile]} {
  set sshcmd "$sshcmd -i $idfile"
eval "spawn $sshcmd -l $userid $device"
# handle initial noise
set timeout 20
while { 1 } {
  expect {
    # command prompt
    # username prompt
    # password prompt
    -nocase -re "word:" {send_user "Public key authentication failed\n"; exit}
    # errors
    timeout     {send_user "Timeout waiting for command prompt\n"; exit}
    eof         {send_user "Connect failed: $expect_out(buffer)\n"; exit}
# disable terminal formatting junk
expect {
    -nocase -re "$prompt"     {}
    eof         {send_user "Connection lost: $expect_out(buffer)\n"; exit}
send "terminal width 0\r"
expect {
# switch to desired mode
if {$configmode} {
  send "configure terminal\r"
  expect {
set timeout 180
send "$command\r"
expect {
    # skip command echo
        send "Y"
        exp_continue
    -re "\r\n"                {send_user "$expect_out(buffer)"; exp_continue}
    -nocase -re "$prompt"     {send "exit\r"}
set timeout 20
expect {
    # second exit needed for logging out from configuration mode
    timeout     {send_user "Timeout waiting for hangup\n"; exit}
    eof         {exit}
expect {
    -nocase -re "$prompt"     {puts "Failed to log out, disconnecting"; exit}
    timeout                   {puts "Timeout waiting for hangup"; exit}
    eof                       {exit}
Tilman
Hello all,
I was searching for the exact same things as Tilman (and for the same reasons, config backup from a management station). It is a pitty that neither scp nor ssh w/ specified command to the switch does not work. I will try your script, though.
Thanks and best regards
Tom
Hi Tilman,
I don't know if you maintain this script anymore, but just FYI this is still not fixed in FW version 1.4.1.3
Small improvement:
In the function that sends the actual command, you have the line
which should be changed to
 -re "\r\n" {send_user -- "$expect_out(buffer)"; exp_continue}
otherwise any commands that output strings starting with a dash ("-") will break the script:
[root@centos7 config_backups]# ./ciscosb-exec readonly@10.x.x.x -i cisco_authkey "show version"
Unit SW version Boot version HW version
bad flag "------------------- ------------------- ------------------- -------------------
": must be -i, -h, -s, -null, -0, -raw, -break, or --
while executing
"send_user "$expect_out(buffer)""
invoked from within
"expect {
# skip command echo
-nocase -re " \\(Y/N\\).*\? *$" {..."
(file "./ciscosb-exec" line 152)
after the fix, it works as EXPECTed (pun intended ;-)
1 1.4.1.3 1.4.0.02 V01
2 1.4.1.3 1.4.0.02 V03
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
