SG300 strange happenings
enforcegroup
Beginner
Beginner
Ok, so I have been configuring the SG-300 28 from both web and cli interfaces.
Int gi2 before int Gi1? WTF?
Also one of my vlans wasn't working on interfaces but was working through the assigned trunk port to my other switch.
I deleted it and recreated it and it is now working.
What are others experiences with this equipment? It's a pain in the rear if this will happen when we have a failure and go to reconfigure a switch and have these same issues.
Luke
1 REPLY 1
David Hornstein
Rising star
Rising star
Hi Luke,
The operating system on the 200,300 and 500 series switches is not traditional Cisco IOS that you would find on a 2960s or 3750X.
So the look and feel is close not not the same. The show run on my SG300-10P showed the following below in blue.
So was the difference between your 300 series switch and my 300 series switch due to firmware differeneces.
I am using the following firmware on my switch as  show below;
SG300(config-if)#do show ver
SW version    1.2.7.76 ( date  19-Jul-2012 time  17:54:43 )
Boot version   1.0.0.4 ( date  08-Apr-2010 time  16:37:57 )
HW version    V01
SG300(config-if)#
interface gigabitethernet1
rmon collection stats 1 owner dave
switchport trunk native vlan 3
voice vlan cos mode all
interface gigabitethernet2
description cli.test.link
spanning-tree portfast
switchport mode access
interface gigabitethernet10
switchport trunk allowed vlan add 3
Don't know enough about your switches working environment to comment on the VLAN failure you had.
  • the sort of question I might ask is what firmware is on your unit?
  • was the so called failing port in vlan  trunk, general, access modes ?
  • do you have a copy of the old running config to validate your suggestion that there was a failure
The product is covered by a tremendous warranty, if you believe the problem with port VLAN assignments fail, please have a chat to the good folk at the Small Business support Center.  www.cisco.com/go/sbsc
let them look at the GUI or CLI config at the time and if there really is an issue let them resolve the issue.
regards Dave
