SG300 switch doesn't have IPv4 Interface configuration
blin
We purchased two SG300 switches. They the same firmware version. One of they has IPv4 Interface configuration.
But other one doesn't have IPv4 Interface. Why?
How can we configure IPv4 Interface if it doesn't show IPv4 Interface?
Jorge Obregon
Hello Blin,
I hope you are doing well.
The switch needs to be in layer 3 as Seb Rupik has recommended you.
From the GUI you can do it following the steps below:
Administration > system settings > system mode from l2 to l3
Note: keep in mind that once you change the operational modem the configuration will be erased so you will need to configure everything from scratch
If you have more questions please let us know.
Thank you for contacting cisco support community
Seb Rupik
Hi there,
I'm not overly familiar with the SG webGUI, but you could try putting it in Layer3 mode. On the CLI issue the following command:
set system mode router
Reboot the swtich and see if it appears. If it doesn't please tell us what version of firmware it is running.
cheers,
Seb.
Jorge Obregon
Hello Blin,
Thank you. That is the problem.
