09-20-2013 05:19 PM
I have an SG300-10P but it doesn't seem to working as expected, so I need some help getting the configuraiton correct. I have a workstation on a vlan (998) but it can't ping a host on the internet (8.8.8.8) but from the switch I can ping 8.8.8.8. I'm sure I'm missing something basic/obvious, but missing it. It looks like the switch will not send traffic back from 192.168.0.2 to 10.47.100.1?
Switch is in Layer 3 mode.
Workstation (10.47.100.150 w/ gateway 10.47.100.1) is on port 3, vlan 998
Firewall (192.168.0.1) is on port 2, vlan 1
vlan1 ip is 192.168.0.2
vlan 998 ip is 10.47.100.1
The interface on the firewall/router is 192.168.0.1. The firewall has a the reverse route on it telling it that in order to reach 10.47.100.1, it has to go through 192.168.0.2. I have a route on the switch telling it to go to 192.168.0.1 for 0.0.0.0.
-PC can ping the firewall (192.168.0.1), vlan1 (192.168.0.2), and vlan 998 (10.47.100.1). It cannot ping google dns 8.8.8.8
-The switch can ping google 8.8.8.8, the firewall (192.168.0.1), vlan 1 (92.168.0.2), and vlan 998 (10.47.100.1), and the workstation (10.47.100.150)
Running config:
vlan database
vlan 998
exit
interface vlan 998
ip address 10.47.100.1 255.255.255.0
exit
interface vlan 1
ip address 192.168.0.2 255.255.255.0
exit
ip route 0.0.0.0 0.0.0.0 192.168.0.1
interface vlan 1
no ip address dhcp
exit
bonjour interface range vlan 1
hostname switcha8b3a1
no snmp-server server
interface gigabitethernet10
exit
interface gigabitethernet3
switchport trunk native vlan 998
exit
09-24-2013 11:59 AM
In case anyone else ever has this issue, I solved it, but not with an SG300. It appears the that SG300 can do intervlan routing but not route internally from an interface. If it does do it, it wasn't documented so I gave up and put in a router.
In short, you need a Cisco router with at least 2 ethernet interfaces with the following configuration:
interface GigabitEthernet0/0
description Direct connect to firewall
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0/1
description To Internal Network Cisco Switch
ip nat inside
duplex auto
speed auto
ip default-gateway 192.168.0.1
ip classless
ip nat inside source list 1 interface GigabitEthernet0/0 overload
access-list 1 permit 10.47.100.0 0.0.0.255
You could probably do routing on a stick (one interface) and some type of vlan setup, but this was easier to implement.
-Chris
09-25-2013 02:27 PM
Hi Chris, the small business switches do not support NAT. Your original post states you have a router
"The interface on the firewall/router is 192.168.0.1."
The switch will work fine on the internet if NAT is not needed, meaning, everything you have is a public IP provided from the ISP.
-Tom
Please mark answered for helpful posts
