SG300 / Wrong module type 63,Board will be rebooted
tpruitt2410
i have a big problem with the SG-300 -10MPP switch after my trainee tried to update the device.
Nothing works anymore, no reset , no network connections, the System light is blinking and via Putty i only get this message.
What happend and what can i do?
Any ideas?
marce1000
 - Depends on what the trainee did, looks like wrong firmware was installed. You may try a factory defaults reset of the device. If that does not help things are worry some.
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
mihail_ip
Can you enter boot menu (startup menu) and what you see there?
Mike
Hi, thanks for your help.
I send the Device back to Cisco.
