SG350-10P inter-VLAN routing
Lukasz1977
Hi all,  I am new one here and I am a  beginner of IT skills. Sorry If I started the topic which maybe was disscued.
I wolud like to ask you where I do a mistake or what's wrong with my switch. Tried to set up inter-VLAN routing in my switch but without success.  I set up IPv4 routing enabled; VLANs created and tried to add IPv4 Routin Table (VLAN2 with 192.168.20.253, etc.) and during this my switch does not show added VALN with IP subnet. It behaves as if it is hanging. I can not to anything as only switch off and on again my switch to start again working...
there is one more thing. Before it I thni k I sholud change swict from later2 to L3. Do I think that it should be done in this particular switch(SG350-10P) in this tab-->VLAN Management/Interface setting ?  If yes, I have done it but from GE2 to GE10. Can't do it for GE1 - becames still L2.
please be understanding and I am asking for clear help step by step. thank you in advance
best
Lukasz
17 Replies 17
great job!!!!
Lukasz
balaji.bandi
We are not aware of your network, so give us more information to understand better, also your configuration.
what is the source IP of your Device, what is the destination of the Device IP, (is this connected to same switch ?)
BB
Hi BB,
So my SG350-10P has IP routing & DHCP server enabled.
It has VLAN1 : 192.168.1.254/24 wehre is my computer connected with its STATIC IP:192.168.1.100 (reserved IP in VLAN1 only for my computer)
VLAN2 : 192.168.2.254/24 whe my Dante devices are connected and are given IPs by DHCP server.
in VLAN2 is also second comuter connected with STATIC IP:192.168.2.200
As I wrote I can internally within te switch PING my Dante devicesa and it works but ca not the same via my computer. I disabled all firewalls and others things I wrote before but still PINGs can not go through VLANs....
Any suggestions ?
Best
Lukasz
