01-26-2021 12:09 AM
after adding two copper cables in the SFP ports and a LAG on the 2 ports of the switch, it started crashing every few minutes. The instability occurred even with only one cable and I found that it does not occur in these two cases:
the LAG in question is used to join 2 switches, an old SG300 and this one, the other switch has no problems.
2147483421 Emergency %SYSLOG-F-OSFATAL: caught segmentation fault exception at address (nil) signal-num = 11 (SIGSEGV) signal-code = 1 (SEGV_MAPERR) reg[00] = 0xfffffff8 reg [01] = 0x0 reg[02] = 0x27 reg[03] = 0x5 reg[04] = 0x0 reg[05] = 0x0 reg[06] = 0x27 reg[07] = 0xa865dc44 reg[08] = 0x10 reg[09] = 0xa865dc44 reg[10] = 0 xb697d38c FP = 0x726fd918 IP = 0xffffffff SP = 0x726fa948 LR = 0xb53aefdc PC = 0xb4510ee4 CPSR = 0x60010030 Fault Address = 0x0 Trap no = 0xe Err Code = 0x15 Old Mask = 0x0 ***** FATAL ERROR ***** Reporting Task: PNPA. Software Version: 2.5.0.83 (date Jun 18 2019 time 16:44:23) base_address=0xb470e000 2147483422 Emergency %SYSLOG-F-OSFATAL: caught segmentation fault exception at address (nil) signal-num = 11 (SIGSEGV) signal-code = 1 (SEGV_MAPERR) reg[00] = 0xfffffff8 reg [01] = 0x0 reg[02] = 0x27 reg[03] = 0x5 reg[04] = 0x0 reg[05] = 0x0 reg[06] = 0x27 reg[07] = 0xa865dc44 reg[08] = 0x10 reg[09] = 0xa865dc44 reg[10] = 0 xb690e38c FP = 0x726fd918 IP = 0xffffffff SP = 0x726fa948 LR = 0xb533ffdc PC = 0xb44a1ee4 CPSR = 0x60010030 Fault Address = 0x0 Trap no = 0xe Err Code = 0x15 Old Mask = 0x0 ***** FATAL ERROR ***** Reporting Task: PNPA. Software Version: 2.5.0.83 (date Jun 18 2019 time 16:44:23) base_address=0xb469f000 2147483423 Emergency %SYSLOG-F-OSFATAL: caught segmentation fault exception at address (nil) signal-num = 11 (SIGSEGV) signal-code = 1 (SEGV_MAPERR) reg[00] = 0xfffffff8 reg [01] = 0x0 reg[02] = 0x27 reg[03] = 0x5 reg[04] = 0x0 reg[05] = 0x0 reg[06] = 0x27 reg[07] = 0xa865dc44 reg[08] = 0x10 reg[09] = 0xa865dc44 reg[10] = 0 xb698c38c FP = 0x726fd918 IP = 0xffffffff SP = 0x726fa948 LR = 0xb53bdfdc PC = 0xb451fee4 CPSR = 0x60010030 Fault Address = 0x0 Trap no = 0xe Err Code = 0x15 Old Mask = 0x0 ***** FATAL ERROR ***** Reporting Task: PNPA. Software Version: 2.5.0.83 (date Jun 18 2019 time 16:44:23) base_address=0xb471d000
I upgraded to version 2.5.5.47 but the problem kept showing up; now I'm checking if the trivial deactivation of PnP is enough to no longer have problems ...
Any advice or idea about it?
Arturo.
Here is the configuration, without special settings:
------------------ show running-config ------------------ config-file-header switch6641e9 v2.5.5.47 / RTESLA2.5.5_930_364_286 CLI v1.0 file SSD indicator encrypted @ ssd-control-start ssd config ssd file passphrase control unrestricted no ssd file integrity control ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0 ! ! unit-type-control-start unit-type unit 1 network gi uplink none unit-type-control-end ! voice vlan oui-table add 0001e3 Siemens_AG_phone________ voice vlan oui-table add 00036b Cisco_phone_____________ voice vlan oui-table add 00096e Avaya___________________ voice vlan oui-table add 000fe2 H3C_Aolynk______________ voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone voice vlan oui-table add 00d01e Pingtel_phone___________ voice vlan oui-table add 00e075 Polycom/Veritel_phone___ voice vlan oui-table add 00e0bb 3Com_phone______________ green-ethernet energy-detect green-ethernet short-reach ip dhcp relay address 192.168.1.1 bonjour interface range vlan 1 hostname switch6641e9 line console exec-timeout 30 exit line ssh exec-timeout 30 exit line telnet exec-timeout 30 exit username xxxxx password encrypted xxxxxxx privilege 15 ip http timeout-policy 1800 clock timezone CET +1 clock summer-time web recurring eu sntp server ip.pool.ntp.org clock dhcp timezone no pnp enable ! interface GigabitEthernet2 spanning-tree link-type point-to-point switchport mode trunk macro description switch !next command is internal. macro auto smartport dynamic_type switch ! interface GigabitEthernet25 ip dhcp snooping trust spanning-tree link-type point-to-point switchport mode trunk macro description switch !next command is internal. macro auto smartport dynamic_type switch ! interface GigabitEthernet26 ip dhcp snooping trust ! interface GigabitEthernet27 ip dhcp snooping trust spanning-tree link-type point-to-point channel-group 2 mode auto switchport mode trunk macro description switch !next command is internal. macro auto smartport dynamic_type switch ! interface GigabitEthernet28 ip dhcp snooping trust channel-group 2 mode auto switchport mode trunk ! interface Port-Channel2 flowcontrol auto description Siwtch ip dhcp snooping trust spanning-tree link-type point-to-point switchport mode trunk macro description switch !next command is internal. macro auto smartport dynamic_type switch ! exit
Log crash:
00--2000 00:00:00 :%SYSLOG-F-OSFATAL: caught segmentation fault exception at address (nil) signal-num = 11 (SIGSEGV) signal-code = 1 (SEGV_MAPERR) reg[00] = 0xfffffff8 reg[01] = 0x0 reg[02] = 0x27 reg[03] = 0x5 reg[04] = 0x0 reg[05] = 0x0 reg[06] = 0x27 reg[07] = 0xa99d069c reg[08] = 0x10 reg[09] = 0xa99d069c reg[10] = 0xb69bc6e8 FP = 0x716fd918 IP = 0xffffffff SP = 0x716fa948 LR = 0xb53e9554 PC = 0xb4540ee4 CPSR = 0x60010030 Fault Address = 0x0 Trap no = 0xe Err Code = 0x15 Old Mask = 0x0 ***** FATAL ERROR ***** Reporting Task: PNPA. Software Version: 2.5.5.47 (date May 6 2020 time 17:25:42) base_address=0xb473e000 00--2000 00:00:00 :%SYSLOG-F-OSFATAL: caught segmentation fault exception at address (nil) signal-num = 11 (SIGSEGV) signal-code = 1 (SEGV_MAPERR) reg[00] = 0xfffffff8 reg[01] = 0x0 reg[02] = 0x27 reg[03] = 0x5 reg[04] = 0x0 reg[05] = 0x0 reg[06] = 0x27 reg[07] = 0xa9ad069c reg[08] = 0x10 reg[09] = 0xa9ad069c reg[10] = 0xb68f66e8 FP = 0x716fd918 IP = 0xffffffff SP = 0x716fa948 LR = 0xb5323554 PC = 0xb447aee4 CPSR = 0x60010030 Fault Address = 0x0 Trap no = 0xe Err Code = 0x15 Old Mask = 0x0
01-26-2021 03:32 AM
- Since you tried latest firmware , guess you need to report this to Cisco :
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
M.
