CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here to learn more.
Dear All,
We are currently having SG350-28P with firmware version 2.5 and are trying to enable VRRP in it but its not getting enabled..
when i checked the Data sheet ( https://www.cisco.com/c/en_in/products/collateral/switches/small-business-smart-switches/data-sheet-c78-737359.html ) i do not see any VRRP support for this model of switches..
Will upgrading the firmware solve my problem and will it support VRRP
Kindly Help
Solved! Go to Solution.
Resiliency with VRRP is supported on Sx550 series switches only. The 220/250/350 series do not support VRRP.
Martin
Martin
Thanks a lot
Ref : https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/350xg/admin_guide/AG_Tesla_350_550.pdf
IP Configuration: VRRP
NOTE This feature is only supported in the 550 family of switches.
M.
Thanks a lot Marce 1000
