09-12-2021 10:01 AM
Linux MARVELL_LINUX 3.4.69 #2 SMP Wed Dec 21 22:02:50 IST 2016
MAC Address : ac:4a:56:f0:90:28.
Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom.
*** Running SW Ver. 2.2.8.4 Date Dec 21 2016 Time 22:00:14 ***
HW version is V05
Base Mac address is: ac:4a:56:f0:90:28
Dram size is : 512M bytes
Dram first block size is : 370688K bytes
Dram first PTR is : 0x80000000
Dram second block size is : 4096K bytes
Dram second PTR is : 0x19000000
Flash size is: 256M
21-Dec-2016 09:29:09 %CDB-I-LOADCONFIG: Loading running configuration.
21-Dec-2016 09:29:09 %CDB-I-LOADCONFIG: Loading startup configuration.
Device configuration:
Slot 1 - SG350-28P
Device 0: GT_98DX3235 (AlleyCat3)
CPLD version is: 0x03
-- Unit Number 1 --
21-Dec-2016 09:29:30 %INIT-I-InitCompleted: Initialization task is completed
The system is going down NOW!
Sent SIGTERM to all processes
Sent SIGKILL to all processes
Requesting system reboot
Restarting system.
09-12-2021 01:09 PM
Try different latest firmware using Xmodem, still issue,. contact Small business TAC for assistance.
09-13-2021 05:37 AM
09-13-2021 06:26 AM
Open a TAC case please.
09-14-2021 01:20 AM
no resolve my problem
09-14-2021 02:02 AM
Hi hashir,
Most probably your switch is for RMA. Please contact TAC via one of the phones on the following link:
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
09-14-2021 02:17 AM
as suggested on above post, Looks for me hardware issue Raise TAC case for RMA
