06-15-2021 04:57 AM
When switches Cisco SG350X-24 reach 497 days without restart, uptime is reseted. No reboot, no SNMP message, just counting from 0 again. Why?? I got more of them and all do the same thing. Using PRTG to monitor over SNMP. FW ver. 2.5.0.92
06-15-2021 05:04 AM
Looks for me Bug, how about the device it self ? (uptime ?)
06-15-2021 05:12 AM - edited 06-15-2021 05:13 AM
Hi Balaji, device uptime is same like PRTG over SNMP.
SWITCH Web interface:
PRTG report:
06-16-2021 02:43 AM
I am thinking below Options :
1. Switch might have rebooted (some reasons)
2. Switch might have crashed and rebooted
I do not belive any evidence for you to look syslog, if you have traps configured Look at PRTG see any information.
if not raise TAC case as suggested to investigate for you.
06-21-2021 01:32 AM
Hi, I am sure that there was no interruption of communication. So no restart (log is in debug mode, so all messages are shown). Rising TAC to try solve it in next FW.
06-21-2021 02:20 AM
i were you, i would go that route, since you did what you can, but still not clue for now.
06-15-2021 09:09 AM
Hi @MartinStuka
It seems like the switch did restart after 497 days, anyway I was reading that other Cisco products (MDS, WLCs, etc) show the same behavior and Cisco in those cases recommends to restart the devices before the 497 days or upgrade the code but couldn't find a specific bug on that platform (SG350X), I guess you could try checking if there's a good/recommended IOS version to upgrade to.
06-16-2021 07:41 AM
Hi Martin,
Thanks for bringing this up. We haven't seen a small business switch with that uptime with no reset/power cycle so far. Please raise a tech support case so one of our engineers can investigate and/or further escalate that software behaviour. Contact details are as follows:
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Martin
