SG350X
sallyonsy
Kindly I am stacking 4 switches SG350X-24P.
For the master switch , I am using two SFP+ ports for ring stacking.
For the other two SFP+ ports , I will be using the other two ports for fiber up-link.
I want to valide this design, is it tested by anyone?
Sally
Deepak Kumar
Yes, it is correct. I used the same option once an ago.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
