11-07-2016 03:39 AM
We are facing a problem in an end user site (a school); the problem symptom is the connectivity, as there is a packet loss happens randomly and the ping between VLANs keep on disconnecting every while (3 or 4 request timed out) and at the same time the CPU is spiking to 80-100% specially during the school working hours and then the ping return to normal, in the same VLAN (L2 switching) there is no problem and everything is working properly.
The Core switch is "2 * SG500-52 52-Port" in Native Stacking mode and the stack connection speed 1G, the firmware downgraded from 1.4.5 to 1.4.2 but the same problem still appeared. it was downgraded as part of testing multiple firmware versions.
The core switch (Stacked SG500 switches) has 19 uplinks, 17 Link of them are aggregation between The core switch (Stacked SG500 switches) and the edge switches, and 2 uplinks without link aggregation just a one connection uplink from the core to the edge switch.
Access list is configured on the switch, but the problem was occurring before the implementation of the access lists.
There are 17 VLAN and DHCP Relay on 15 out of 17 VLAN,DHCP server role in Windows Server 2008.
Switch |
Location |
IP Address |
Core Cisco (SG500-52) * 2 |
Main Cabinet |
192.168.101.1 |
Cisco (SG500-28) |
Server Cabinet |
192.168.101.2 |
HP (1810-24) |
Main Cabinet |
192.168.101.3 |
Cisco (SG300-28P) |
DT Lab |
192.168.101.4 |
Cisco (SG300-28P) |
S Lab 1 |
192.168.101.5 |
Cisco (SG300-28P) |
S Lab 2 |
192.168.101.6 |
Cisco (SG300-28P) |
S Lab 3 |
192.168.101.7 |
Cisco (SG300-28P) |
J Lab 1 |
192.168.101.8 |
Cisco (SG300-28P) |
J Lab 2 |
192.168.101.9 |
Cisco (SG300-28P) |
LSD |
192.168.101.10 |
Cisco (SG300-28P) |
S SLab |
192.168.101.20 |
Cisco (SG300-52P) |
S1 |
192.168.101.21 |
HP (1810-24) |
S2 |
192.168.101.22 |
HP (1810-24) |
S3 |
192.168.101.23 |
Cisco (SG300-28P) |
Meeting |
192.168.101.24 |
HP (1810-24) |
Senior English Room |
192.168.101.25 |
HP (1810-48) |
N3 |
192.168.101.30 |
HP (1810-48) |
N4 |
192.168.101.31 |
Cisco (SG300-52P) |
N5 |
192.168.101.32 |
Cisco (SG300-52P) |
192.168.101.40 |
Cisco (SG300-28P) |
GYM 1.1 B |
192.168.101.50 |
Cisco (SG300-52P) |
GYM 1.2 B |
192.168.101.51 |
Cisco (SG300-28P) |
GYM 1st |
192.168.101.52 |
Cisco (SG300-52P) |
GYM 2nd |
192.168.101.53 |
Cisco (SG300-52P) |
GYM 3rd |
192.168.101.54 |
So all on all, I'm trying to find the source of the disconnection problem and the sudden CPU spikes.
may you please assist me to solve this problem.
Best regards
Solved! Go to Solution.
11-21-2016 01:06 AM
that CPU spikes can be related to occasional switching loops/storms in your network. I assume that your SG500 stack is the only routing device from whole switching environment, right?
11-21-2016 01:06 AM
11-22-2016 10:53 PM
Enabling BPDU guard on all access ports and root guard on all Core switch downlink ports had been applied and the network now stable. will wait for a couple of days and update you.
Appreciate your advise.
12-04-2016 03:51 AM
Hi Michal,
i would like to thank you for your help, you have pinpointed the problem from the first shot.
one extra question if you may.
we already applied the SYSLOG on all switches from day 1. i was not noticing major or repeated topology changing on the syslog server. and for sure i did not find any log of re-electing the root bridge. so is there any article or explination why the root guard was such a use.
Best regards and many thanks again.
12-04-2016 04:19 AM
I am glad that it helped.
regards to your question: there could be two possible explanations:
anyway all events resulted from BPDU guard or Root Guard activities are logged so you should see them appearing in syslog output.
