CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here to learn more.
maybe someone can help me with my problem
The Network:
I have a SG500-52P as a Layer 3 Switch in my network and it holds 5 different vlan:
116 Data 172.16.0.0
117 Wifi 172.17.0.0
119 Voip 172.19.0.0
118 Guest 172.18.0.0
1 Management (not defined yet)
I want to use some ip phones from a vendor called snom, so i set up a entry in the telefon oui which automatically tags the devices
to the right vlan (119). I also set up a freeradius server for doing a mac auth for the dynamic vlan assignment for computers etc.
For this i have to enable the port authentication on the ports. So if i use a phone and connect then a computer into the switch port which is built in into that phone the port gets the right vlans (116 119) and the devices getting different ips from different dhcp servers.
But if i disconnect a phone+computer and connect it again the complete switch reboots and i really dont know why.
I tested different scenarios with the same end until i disabled the port authentication which is needed to do the dynamic vlans through the radius server.
Then the reboots stopped but this means i'm not able to do dynamic vlans.
It seems that the switch cannot handle telefonoui and radius auth at the same time.
Sorry for my bad englisch
Hello Sascha, this is an interesting scenario.
Could you provide a config file (removing sensitive information) along with the fatal error the switch produces before it reboots?
-Tom
Please mark answered for helpful posts
