01-23-2013 07:00 PM
Hi All,
I have just configured up a sg500 with a lacp trunk to an upstream switch.
I am getting native vlan mismatch on the individual ports of the lacp team.
24-Jan-2013 12:54:48 %CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected on interface gi1/1/24.
24-Jan-2013 12:57:35 %CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected on interface gi1/1/48.
The following is showing the correct native vlan
BH-WS-AC-2#show int switchport port 1
Port : Po1
Port Mode: Trunk
Gvrp Status: disabled
Ingress Filtering: true
Acceptable Frame Type: admitAll
Ingress UnTagged VLAN ( NATIVE ): 2000
Port is member in:
Vlan Name Egress rule Port Membership Type
1200 1200 Tagged Static
1210 Management Tagged Static
1212 1212 Tagged Static
2000 Native Vlan Untagged Static
But the following shows that the individual ports think they are the default vlan 1.
BH-WS-AC-2#show int switchport gi1/1/48
Port : gi1/1/48
Port Mode: Trunk
Ingress UnTagged VLAN ( NATIVE ): 1
Port is member in:
The following shows the LACP as up:
BH-WS-AC-2#show int Port-Channel 1
Load balancing: src-dst-mac-ip.
Gathering information...
Channel Ports
Po1 Active: gi1/1/24,gi1/1/48
Is this normal behaviour? as i cannot set the native vlan directly on the gi interface due to it being in the trunk.
Simon
01-23-2013 07:44 PM
Hi Simon, native vlan mismatch is a cosmetic error from CDP. It won't affect services provided the vlans are a member of the ports in question.
You can set the native vlan while it is within the lag. On the SX500 it would be
config t
int po1
switchport trunk native vlan xxxx
The port channel is the same as any other individual port so it's not a problem. 802.1q specifies the native vlan is the untagged member, if you want to get rid of the error, make sure the untagged vlans match up on both sides.
-Tom
Please mark answered for helpful posts
