10-22-2018 06:02 PM
I have a Cisco SG500-52 switch.
On boot the Fan light comes on green, and the System light starts blinking green. No other lights show (no port lights at all).
I tried rebooting or resetting the switch using the small reset hole / button, but it doesn't respond at all. Not after 10 seconds, nor 30 seconds, nor a minute.
Any ideas? This switch did work at one time.
10-24-2018 09:24 AM
Console is interesting.
It starts with this message:
MAC address is not valid!
MAC address is not valid, you can't use multicast or broadcast address.
Enter MAC address and press ENTER( XX:XX:XX:XX:XX:XX ) :
So it is asking me to enter in a MAC address? I left it blank and pressed enter just to see what would happen. Again it repeated:
then Error occurred - MAC address not changed.
Then it asked for:
Enter Hardware Revision (XX.XX.XX):
Again I left it blank and pressed enter;
Hardware Revision was not changed.
Then it asked for:
Enter Serial Number:
Again blank and enter:
Serial Number was not changed.
Then it cycled back to the beginning:
Seems like it is doing the initial setup that they do in the factory, maybe?
There is a Serial Number
and a MAC ID
on a barcode sticker on the back of the unit. Maybe I should try entering these values? However, I have no idea what to put for Hardware Revision
. There is a PID VID
on the same sticker which is SG500-52-K9 V01
but I'm not sure how to translate that into the XX.XX.XX
format that the Console is requesting.
11-11-2018 12:00 AM - edited 11-11-2018 12:04 AM
It seems I have the similar issue with the same model of SG500-52. With that difference that I do have a valid MAC-address. I miss serial and hw version, still. I would like to set those as well, but how do I trigger that initial factory wipe of the device?
