Greetings.
I just recently purchased the SG500-52 Switch and is currently trying to configure the device for inter-VLAN connection and internet access.
I have set the device to L3 Mode. The gateway config IP is 192.168.9.254. The default VLAN ID is 1. The PC used for configuring the switch is plugged into the GE2 LAN port, and the internet is plugged into the GE48 LAN port.
I have 3 VLANs set up. VLAN 20 for Sales, VLAN 60 for Accounting, and VLAN 90 for IT. Port membership are as follows. All untagged
- GE1,GE2,GE25,GE26 are VLAN 20
- GE6 is VLAN 60
- GE9 is VLAN 90
- GE48 has membership of all VLANs. (1UP, 20T, 60T, 90T)
All ports are set to trunk mode, except for GE48, which has been set to General. IPs are manually configured with DHCP turned off.
From this PC (192.168.20.1), I can Ping and detect the computers within the same VLAN (VLAN 20) but computers in the different VLAN is completely inaccessible. Furthermore, I cannot access the internet.
Please help. Any suggestions would be appreciated. If you need more info, please do ask.
P.S. Sorry for my English.
