CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
479
Beginner
SG550XG-24F Stack
it is possible to stack two sg550xg-24f using an "sfp-h10gb-cu" cable , and manage them as a unique switch of 48 ports?
in this case, should i configure a LAG between two port on different switches? (ex xg1 on sw1 and xg1 on sw2) in way to have 20 gb of link.
4 REPLIES 4
Re: SG550XG-24F Stack
Yes, the SFP-H10GB-CU1M/3M/5M is on the list of support modules for SG550XG.
As far as your second question, it depends on what you are trying to achieve. Please note that even if you bundle 2 x 10Gb ports, you won't have 20GB to any one device at a time.
Beginner
Thanks for the ansewer,
but the question still remains:
If i stack two sg550xg-24, with one cable from the "stack management" menu,
i see a unique appliance of 48 ports? or the second switch  works as back mode?
Highlighted
Both devices (or as many as you have in the stack) will be managed under a single IP address as if it was a single unit.
Beginner
Thank you for replay,
but i don't understand,
I see, one switch with 48 ports? Yes or no?
