SG550XG to SG500X - SFP issues
athorn001
We have Cisco SG500X-48 and SG550XG-24F, and we're using the the 10Gb SR modules. When we light the fiber with these modules, we get the error on the SG500X-48. I actually have a set of SG550XG's (550XG-8F8T)  that light up fine between the two with the same module.
Below is the error on the SG500X-48. On the SG550XG it just shows the link go up and down.
{ERROR}
2147483512 2016-Apr-20 13:40:47 Informational %NSFP-I-SFPGibicRemoved: te1/1/1 SFP port is not present
2147483513 2016-Apr-20 13:40:24 Warning %LINK-W-Down: Vlan 66
2147483514 2016-Apr-20 13:40:24 Warning %LINK-W-Down: Vlan 5, aggregated (1)
2147483515 2016-Apr-20 13:40:24 Warning %LINK-W-Down: te1/1/1, aggregated (1)
2147483516 2016-Apr-20 13:40:23 Notice %LINK-N-PortConfRecover: Port te1/1/1 configured to speed 1G
2147483517 2016-Apr-20 13:40:23 Informational %NSFP-I-SFPGibicDetected: te1/1/1 SFP port is present, module type - 1000BASE-LX
2147483518 2016-Apr-20 13:40:22 Informa tional %LINK-I-Up: Vlan 66
2147483519 2016-Apr-20 13:40:22 Informational %LINK-I-Up: Vlan 5, aggregated (1)
2147483520 2016-Apr-20 13:40:22 Informational %LINK-I-Up: te1/1/1, aggregated (1)
2147483521 2016-Apr-20 13:40:22 Warning %LINK-W-Down: Vlan 5
2147483522 2016-Apr-20 13:40:22 Warning %LINK-W-Down: te1/1/1
2147483523 2016-Apr-20 13:40:22 Informational %LINK-I-Up: Vlan 5
2147483524 2016-Apr-20 13:40:22 Informational %LINK-I-Up: te1/1/1
{/ERROR}
5 Replies 5
athorn001
I'm also using the latest firmware for both switches.
I'm having similar issues.
The SFP is detected and removed again.
# show fiber-ports optical-transceiver interface TengigabitEthernet2/1/1
gives most of the time:
te2/1/1 N/A N/A N/A N/A N/A N/A
and sometimes:
te2/1/1 38 3.33 5.25 0.58 0.00 N/A
before it goes back to the "N/A" line
log says:
24-Jan-2017 01:11:05 %LINK-I-Up: te2/1/1, aggregated (16)
24-Jan-2017 01:11:06 %NSFP-I-SFPGibicDetected: te2/1/1 SFP port is present, module type - 10G BASE-SR, aggregated (6)
24-Jan-2017 01:11:07 %LINK-W-Down: te2/1/1, aggregated (16)
24-Jan-2017 01:11:08 %NSFP-I-SFPGibicRemoved: te2/1/1 SFP port is not present, aggregated (6)
the setup is that there are stacks of 2 SG500X, 2 10G stack links, plus a pair of uplinks to a vpc pair of nexus 7k switches. (on te1/1/1 and te2/1/1). Sometimes the link comes up on both uplinks directly after a reload of the sg500x stack, but almost never if the switches are up and the link is disconnected and reconnected again.
Trying a 10G-CU-5M cable the link does come up, just trying with "real" SFPs the link shows this issue., regardless what types of 10G SFPs I tried.
happened on fw:1.4.7.5,1.4.7.6,1.4.5.02,1.4.2.4,1.4.1.3 ...
The release notes mention CQ135073, actually this might just be a tougher case of the same.
i had also same problem however, solved. But i can not communicate between switches.
i connect SG550XG to SG500X by sfp supported module for 10G. but it is not connecting. Is there any special command for using fiber connectivity?
OM4 Multi-mode 50/125µm, Duplex, LC
SFP-10G-SR
SG550XG >> interface  te1/0/9
ip address 192.168.3.1 255.255.255.0
I/F Status  admin/oper
up/up
SG500X >> interface  te1/1/1
ip address 192.168.3.2 255.255.255.0
up/down
I see a similar issue with a Nexus 3548 :(
jane
SG300 too
System Description: SG300-28SFP 28-Port Gigabit Managed SFP Switch
System Up Time (days,hour:min:sec): 22,23:57:43
System Contact:
System Name: SG300-PE-06
System Location:
System MAC Address: c4:b9:cd:46:xx:xx
System Object ID: 1.3.6.1.4.1.9.6.1.83.28.5
Fans Status: OK
SW version 1.4.2.4 ( date 21-Dec-2015 time 16:45:33 )
Boot version 1.3.5.06 ( date 21-Jul-2013 time 15:12:10 )
HW version V03
09-Feb-2018 02:29:42 :%STP-W-PORTSTATUS: gi1: STP status Forwarding
09-Feb-2018 02:29:41 :%STP-W-PORTSTATUS: gi2: STP status Forwarding
09-Feb-2018 02:29:41 :%STP-W-PORTSTATUS: gi11: STP status Forwarding
09-Feb-2018 02:29:37 :%LINK-I-Up: gi1
09-Feb-2018 02:29:36 :%LINK-I-Up: gi2
09-Feb-2018 02:29:36 :%LINK-I-Up: gi11
09-Feb-2018 02:29:35 :%STP-W-PORTSTATUS: gi17: STP status Forwarding
09-Feb-2018 02:29:35 :%STP-W-PORTSTATUS: gi15: STP status Forwarding
09-Feb-2018 02:29:35 :%STP-W-PORTSTATUS: gi4: STP status Forwarding
09-Feb-2018 02:29:34 :%STP-W-PORTSTATUS: gi3: STP status Forwarding
09-Feb-2018 02:29:33 :%STP-W-PORTSTATUS: gi13: STP status Forwarding
09-Feb-2018 02:29:31 :%LINK-I-Up: gi17
09-Feb-2018 02:29:31 :%LINK-I-Up: gi15
09-Feb-2018 02:29:31 :%LINK-I-Up: gi4
09-Feb-2018 02:29:30 :%LINK-I-Up: gi3
09-Feb-2018 02:29:29 :%LINK-W-Down: gi15
09-Feb-2018 02:29:29 :%LINK-I-Up: gi13
09-Feb-2018 02:29:28 :%LINK-W-Down: gi4
09-Feb-2018 02:29:28 :%LINK-W-Down: gi17
09-Feb-2018 02:29:28 :%LINK-W-Down: gi2
09-Feb-2018 02:29:27 :%LINK-W-Down: gi11
09-Feb-2018 02:29:27 :%LINK-W-Down: gi3
09-Feb-2018 02:29:27 :%LINK-W-Down: gi13
09-Feb-2018 02:29:20 :%STP-W-PORTSTATUS: gi4: STP status Forwarding
09-Feb-2018 02:29:20 :%STP-W-PORTSTATUS: gi14: STP status Forwarding
09-Feb-2018 02:29:18 :%STP-W-PORTSTATUS: gi12: STP status Forwarding
09-Feb-2018 02:29:17 :%STP-W-PORTSTATUS: gi15: STP status Forwarding
09-Feb-2018 02:29:17 :%STP-W-PORTSTATUS: gi2: STP status Forwarding
09-Feb-2018 02:29:17 :%STP-W-PORTSTATUS: gi1: STP status Forwarding
09-Feb-2018 02:29:16 :%NSFP-I-SFPGibicDetected: gi16 SFP port is present
09-Feb-2018 02:29:16 :%NSFP-I-SFPGibicRemoved: gi5 SFP port is not present
09-Feb-2018 02:29:16 :%STP-W-PORTSTATUS: gi17: STP status Forwarding
09-Feb-2018 02:29:16 :%STP-W-PORTSTATUS: gi13: STP status Forwarding
09-Feb-2018 02:29:16 :%STP-W-PORTSTATUS: gi11: STP status Forwarding
09-Feb-2018 02:29:16 :%LINK-I-Up: gi4
09-Feb-2018 02:29:16 :%STP-W-PORTSTATUS: gi3: STP status Forwarding
09-Feb-2018 02:29:15 :%LINK-I-Up: gi14
09-Feb-2018 02:29:15 :%NSFP-I-SFPGibicRemoved: gi16 SFP port is not present
09-Feb-2018 02:29:15 :%LINK-W-Down: gi14
09-Feb-2018 02:29:15 :%NSFP-I-SFPGibicDetected: gi5 SFP port is present
09-Feb-2018 02:29:15 :%LINK-W-Down: gi4
09-Feb-2018 02:29:14 :%NSFP-I-SFPGibicRemoved: gi1 SFP port is not present
09-Feb-2018 02:29:14 :%NSFP-I-SFPGibicDetected: gi14 SFP port is present
09-Feb-2018 02:29:14 :%NSFP-I-SFPGibicDetected: gi4 SFP port is present
09-Feb-2018 02:29:14 :%NSFP-I-SFPGibicDetected: gi1 SFP port is present
09-Feb-2018 02:29:13 :%NSFP-I-SFPGibicDetected: gi16 SFP port is present
09-Feb-2018 02:29:13 :%LINK-I-Up: gi12
09-Feb-2018 02:29:13 :%LINK-W-Down: gi12
09-Feb-2018 02:29:13 :%NSFP-I-SFPGibicRemoved: gi14 SFP port is not present
09-Feb-2018 02:29:13 :%NSFP-I-SFPGibicRemoved: gi5 SFP port is not present
09-Feb-2018 02:29:13 :%NSFP-I-SFPGibicRemoved: gi4 SFP port is not present
09-Feb-2018 02:29:13 :%LINK-I-Up: gi15
09-Feb-2018 02:29:13 :%LINK-I-Up: gi2
09-Feb-2018 02:29:13 :%LINK-I-CHNGCOMBOMEDIA: Media changed from copper media to fiber media on port gi27.
09-Feb-2018 02:29:13 :%NSFP-I-SFPGibicRemoved: gi16 SFP port is not present
09-Feb-2018 02:29:12 :%LINK-W-Down: gi15
09-Feb-2018 02:29:12 :%NSFP-I-SFPGibicDetected: gi5 SFP port is present
09-Feb-2018 02:29:12 :%LINK-W-Down: gi2
09-Feb-2018 02:29:12 :%NSFP-I-SFPGibicDetected: gi28 SFP port is present
09-Feb-2018 02:29:12 :%NSFP-I-SFPGibicDetected: gi27 SFP port is present
09-Feb-2018 02:29:12 :%NSFP-I-SFPGibicRemoved: gi26 SFP port is not present
09-Feb-2018 02:29:12 :%NSFP-I-SFPGibicRemoved: gi25 SFP port is not present
09-Feb-2018 02:29:12 :%NSFP-I-SFPGibicDetected: gi24 SFP port is present
09-Feb-2018 02:29:12 :%NSFP-I-SFPGibicDetected: gi23 SFP port is present
09-Feb-2018 02:29:12 :%NSFP-I-SFPGibicDetected: gi22 SFP port is present
09-Feb-2018 02:29:12 :%NSFP-I-SFPGibicDetected: gi20 SFP port is present
09-Feb-2018 02:29:12 :%NSFP-I-SFPGibicRemoved: gi17 SFP port is not present
09-Feb-2018 02:29:12 :%NSFP-I-SFPGibicDetected: gi16 SFP port is present
09-Feb-2018 02:29:12 :%NSFP-I-SFPGibicRemoved: gi13 SFP port is not present
09-Feb-2018 02:29:12 :%NSFP-I-SFPGibicRemoved: gi11 SFP port is not present
09-Feb-2018 02:29:12 :%NSFP-I-SFPGibicRemoved: gi9 SFP port is not present
09-Feb-2018 02:29:12 :%NSFP-I-SFPGibicDetected: gi8 SFP port is present
09-Feb-2018 02:29:12 :%NSFP-I-SFPGibicRemoved: gi7 SFP port is not present
09-Feb-2018 02:29:12 :%NSFP-I-SFPGibicRemoved: gi5 SFP port is not present
09-Feb-2018 02:29:12 :%NSFP-I-SFPGibicRemoved: gi3 SFP port is not present
09-Feb-2018 02:29:12 :%NSFP-I-SFPGibicRemoved: gi1 SFP port is not present
09-Feb-2018 02:29:11 :%LINK-I-Up: gi17, aggregated (1)
09-Feb-2018 02:29:11 :%LINK-I-Up: gi13, aggregated (1)
09-Feb-2018 02:29:11 :%LINK-I-Up: gi11
09-Feb-2018 02:29:11 :%NSFP-I-SFPGibicDetected: gi19 SFP port is present
09-Feb-2018 02:29:11 :%LINK-W-Down: gi17
09-Feb-2018 02:29:11 :%LINK-I-Up: gi4
09-Feb-2018 02:29:11 :%LINK-I-Up: gi3
09-Feb-2018 02:29:11 :%LINK-I-Up: gi15
09-Feb-2018 02:29:11 :%LINK-W-Down: gi13, aggregated (1)
09-Feb-2018 02:29:11 :%LINK-I-Up: gi2
09-Feb-2018 02:29:05 :%LINK-W-Down: gi3
09-Feb-2018 02:29:05 :%LINK-W-Down: gi2
09-Feb-2018 02:29:04 :%LINK-W-Down: gi11
09-Feb-2018 02:29:04 :%LINK-W-Down: gi15
09-Feb-2018 02:29:04 :%LINK-W-Down: gi13
09-Feb-2018 02:29:04 :%LINK-W-Down: gi17
09-Feb-2018 02:29:04 :%LINK-W-Down: gi4
09-Feb-2018 01:17:48 :%STP-W-PORTSTATUS: gi15: STP status Forwarding, aggregated (1)
09-Feb-2018 01:17:44 :%LINK-I-Up: gi15, aggregated (1)
09-Feb-2018 01:17:42 :%LINK-W-Down: gi15, aggregated (1)
09-Feb-2018 01:17:30 :%STP-W-PORTSTATUS: gi15: STP status Forwarding
09-Feb-2018 01:17:25 :%LINK-I-Up: gi15, aggregated (1)
09-Feb-2018 01:17:25 :%LINK-W-Down: gi15, aggregated (1)
09-Feb-2018 01:17:24 :%LINK-I-Up: gi15
09-Feb-2018 01:17:14 :%LINK-W-Down: gi15
09-Feb-2018 01:16:12 :%STP-W-PORTSTATUS: gi12: STP status Forwarding, aggregated (1)
09-Feb-2018 01:16:07 :%LINK-I-Up: gi12, aggregated (2)
09-Feb-2018 01:16:07 :%LINK-W-Down: gi12, aggregated (2)
09-Feb-2018 01:15:52 :%STP-W-PORTSTATUS: gi12: STP status Forwarding
09-Feb-2018 01:15:47 :%LINK-I-Up: gi12, aggregated (1)
09-Feb-2018 01:15:47 :%LINK-W-Down: gi12, aggregated (1)
09-Feb-2018 01:15:43 :%LINK-W-Down: gi12
09-Feb-2018 01:13:46 :%STP-W-PORTSTATUS: gi1: STP status Forwarding, aggregated (1)
09-Feb-2018 01:13:42 :%LINK-I-Up: gi1, aggregated (2)
09-Feb-2018 01:13:42 :%LINK-W-Down: gi1, aggregated (2)
09-Feb-2018 01:13:26 :%STP-W-PORTSTATUS: gi1: STP status Forwarding
09-Feb-2018 01:13:21 :%LINK-I-Up: gi1, aggregated (1)
09-Feb-2018 01:13:21 :%LINK-W-Down: gi1
09-Feb-2018 01:13:19 :%LINK-I-Up: gi1
09-Feb-2018 01:12:55 :%STP-W-PORTSTATUS: gi2: STP status Forwarding
09-Feb-2018 01:12:50 :%LINK-I-Up: gi2, aggregated (1)
09-Feb-2018 01:12:50 :%LINK-W-Down: gi2
09-Feb-2018 01:12:49 :%STP-W-PORTSTATUS: gi4: STP status Forwarding
09-Feb-2018 01:12:49 :%LINK-I-Up: gi2
09-Feb-2018 01:12:49 :%STP-W-PORTSTATUS: gi17: STP status Forwarding
09-Feb-2018 01:12:48 :%STP-W-PORTSTATUS: gi11: STP status Forwarding
09-Feb-2018 01:12:48 :%STP-W-PORTSTATUS: gi3: STP status Forwarding
09-Feb-2018 01:12:47 :%STP-W-PORTSTATUS: gi13: STP status Forwarding
09-Feb-2018 01:12:45 :%NSFP-I-SFPGibicRemoved: gi19 SFP port is not present
09-Feb-2018 01:12:45 :%NSFP-I-SFPGibicDetected: gi18 SFP port is present
09-Feb-2018 01:12:45 :%LINK-I-Up: gi4, aggregated (1)
09-Feb-2018 01:12:45 :%LINK-W-Down: gi4
09-Feb-2018 01:12:44 :%NSFP-I-SFPGibicDetected: gi19 SFP port is present
09-Feb-2018 01:12:44 :%LINK-I-Up: gi17, aggregated (1)
09-Feb-2018 01:12:44 :%LINK-W-Down: gi17
09-Feb-2018 01:12:44 :%LINK-I-Up: gi11, aggregated (1)
09-Feb-2018 01:12:44 :%NSFP-I-SFPGibicRemoved: gi18 SFP port is not present
09-Feb-2018 01:12:44 :%LINK-W-Down: gi11, aggregated (1)
09-Feb-2018 01:12:44 :%LINK-I-Up: gi3, aggregated (1)
09-Feb-2018 01:12:44 :%LINK-W-Down: gi3
09-Feb-2018 01:12:43 :%LINK-I-Up: gi4
09-Feb-2018 01:12:43 :%LINK-I-Up: gi13, aggregated (1)
09-Feb-2018 01:12:43 :%LINK-W-Down: gi13, aggregated (1)
09-Feb-2018 01:12:42 :%LINK-I-Up: gi11
09-Feb-2018 01:12:42 :%LINK-I-Up: gi3
09-Feb-2018 01:12:42 :%LINK-I-Up: gi17
09-Feb-2018 01:12:41 :%LINK-I-Up: gi13
09-Feb-2018 01:12:41 :%LINK-W-Down: gi4
09-Feb-2018 01:12:41 :%LINK-W-Down: gi11
09-Feb-2018 01:12:40 :%LINK-W-Down: gi2
09-Feb-2018 01:12:40 :%LINK-W-Down: gi17
09-Feb-2018 01:12:40 :%LINK-W-Down: gi3
09-Feb-2018 01:12:39 :%LINK-W-Down: gi13
09-Feb-2018 01:12:29 :%STP-W-PORTSTATUS: gi2: STP status Forwarding
09-Feb-2018 01:12:29 :%STP-W-PORTSTATUS: gi11: STP status Forwarding
09-Feb-2018 01:12:28 :%STP-W-PORTSTATUS: gi17: STP status Forwarding
09-Feb-2018 01:12:28 :%STP-W-PORTSTATUS: gi13: STP status Forwarding
09-Feb-2018 01:12:28 :%STP-W-PORTSTATUS: gi4: STP status Forwarding
09-Feb-2018 01:12:28 :%STP-W-PORTSTATUS: gi3: STP status Forwarding
09-Feb-2018 01:12:25 :%LINK-I-Up: gi2, aggregated (1)
09-Feb-2018 01:12:25 :%LINK-W-Down: gi2
09-Feb-2018 01:12:24 :%LINK-I-Up: gi11, aggregated (1)
09-Feb-2018 01:12:24 :%NSFP-I-SFPGibicRemoved: gi19 SFP port is not present
09-Feb-2018 01:12:24 :%NSFP-I-SFPGibicDetected: gi18 SFP port is present
09-Feb-2018 01:12:24 :%LINK-W-Down: gi11
09-Feb-2018 01:12:23 :%LINK-I-Up: gi17
09-Feb-2018 01:12:23 :%LINK-I-Up: gi13
09-Feb-2018 01:12:23 :%LINK-I-Up: gi4
09-Feb-2018 01:12:23 :%LINK-I-Up: gi3
09-Feb-2018 01:12:23 :%LINK-I-Up: gi2
09-Feb-2018 01:12:23 :%NSFP-I-SFPGibicDetected: gi19 SFP port is present
09-Feb-2018 01:12:23 :%NSFP-I-SFPGibicRemoved: gi18 SFP port is not present
