SGE2000P config save
jlixfeld
If I make a change to the config on my SGE2000P via the GUI, do I manually have to save the running config to the startup config like in Cisco land, or does it behave like a Linksys where as soon as you click "apply" the change is automatically saved and thus persistent across reboots?
chrcoope
It must be saved. I have attached a doc that shows where this is done. Hope this helps.
Christopher
