CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
2476
Highlighted
Beginner
SGE2000P config save
If I make a change to the config on my SGE2000P via the GUI, do I manually have to save the running config to the startup config like in Cisco land, or does it behave like a Linksys where as soon as you click "apply" the change is automatically saved and thus persistent across reboots?
1 REPLY 1
Highlighted
Beginner
It must be saved. I have attached a doc that shows where this is done. Hope this helps.
Christopher
