CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
1143
troyday88
Beginner
SGE2010P - Connectivity issues
We have 3 SGE2010P all set up as layer 2 switches with no DHCP, no VLAN configuration. They are just acting like switches. We are a small office of about 100 people so there is no need for me to configure anything on the switches. I have a problem where clients will lose connectivity for a short amount of time (say maximum of 10 seconds). The network cable will give no indication that it has been unplugged and I have even tested it being directly connected to the switch (not running through the internal cables) and still the same problem. Some clients just wait it out for that short period and it comes good, but others will have to remove the network cable and then plug it back in straight away. It doesn't appear to be affecting everyone however.
Thanks.
1 REPLY 1
troyday88
Beginner
I am still getting these issues. Is there some way I can check on the switch to see if a port is getting hammered or something?
