CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
2790
Highlighted
Beginner
SLM2008 VLAN
Hi, VLAN newbie here!
I need to setup a VLAN using a SLM2008 and connect it to our Fortigate Internet Firewall.  I'm doing this to segregate the SLM2008 traffic from the main network which is already connected to the firewall.  I have created VLAN #200 in the SLM2008.  I have read all the SLM2008 documentation and spent quite a lot of time on these forums but can't seem to get this working.
Questions:
1. The firewall is seen on the network as another multi-port hub, so does this mean that the SLM2008 must be connected to it via a VLAN trunk link?
2. On this forum someone said you must use Port 1 of the SLM2008 if you want to do trunking?  True?
3. If #2 is correct, then how do you setup port 1 as a trunk?  There is no trunk option in the web gui.
Thanks in advance!
Marty
Everyone's tags (3)
1 REPLY 1
Beginner
Re: SLM2008 VLAN
I finally found the answer by discovering this page.  The Cisco documenation is incomplete
on setting up the SLM2008 as a VLAN trunk.  Follows the steps given here:
http://www.jarmanator.net/kb/slm2008vlan.htm
Marty
