01-18-2020 11:26 AM
Hey folks -
I just installed a new pair of small business switches here in the home office. One is an SG350XG, the other a SX550X. Both have been upgraded to the latest 2.5.0.90 code, and both are showing the same problem: very slow SSH login and CLI response. This was also happening with the version of code they shipped with: 2.4.0.94. It feels like I'm typing into a 9600 baud dial-up BBS; hell the serial console is probably faster.
The output from the SSH/CLI login is pretty snappy. It's just the input; almost like there's a buffer problem or some such.
Since I can telnet in and get snappy responses both input and output, this leads me to believe that the switches' SSH client is not up to par. Or that their respective CPU can't deal with decrypting the SSH packets properly. I'm not 100% though. I've read another thread on this same problem and it seems like one of the problems was with cut and paste. I'm not even doing that, just typing commands in.
Interestingly, I also have an older SG500-28. Its SSH logins are quite quick.
Any suggestions or ideas?
Thanks.
02-24-2021 01:31 AM
Hi, do you got any solution for this problem? I run an SX550X-24FT with the latest firmware Version: 2.5.5.47 and have the same problem. Telnet is very snappy but SSH is very laggy
Br
Chris
02-24-2021 01:57 AM
No solution or work around whatsoever. I've given up on SSH and use telnet.
02-24-2021 02:30 AM
Do you use snmp?
what is your cpu utilization?
#show cpu utilization
02-24-2021 03:27 AM
@Stan1212 wrote:Do you use snmp?
It's not a CPU utilization problem. The problem apparently lies within the switch's ssh implementation.
CPU utilization service is on.
CPU utilization
five seconds: 1%; one minute: 2%; five minutes: 1%
02-24-2021 03:56 AM - edited 02-24-2021 04:11 AM
same on my switch, its idle in my test enviroment, also no snmp queries.
CPU utilization
five seconds: 1%; one minute: 1%; five minutes: 1%
02-24-2021 03:36 AM
Ah that's something new. I observe the similar issues during snmp polls of my cisco sg350xg-25t. Cpu spikes and ssh perfomance falls dramatically.
