CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
340
Beginner
small configure help please? I have 3 300-28 switches, I want to connect them and avoid stp (stp setup)
HI!
I have a small network. I have 3 300-28 cisco switches. I already connected my 3 servers  and clients with the switch 1 and now I want to add more clients and I need to add my other two switches in the network. Please guide me with the simple configuration So I can connect them all and avoid loop (stp). Thanks
Everyone's tags (4)
3 REPLIES 3
You can configure the links
You can configure the links between the switches as a trunk and all other ports where hosts are connected can be configured as access ports with port-fast configured. That may help.
Nagaraja
Beginner
Hi Nagaraja Thanthry!Thanks
Thanks for your reply. I am implementing it tomorrow. By just conecting the switches together at trunk ports  will there be no loop? I don't want my network chowk. I hope it will work well. I might need further help, please reply.
1. I will do setting on all switches. Assign IP addresses to switches (to Vlan 1 default).
2. Set one port (e.g 28) as trunk and all others as Access on all three switches.
3. Then I will connect the switches with each other at trunk ports. Hope there will be no loop in this setting.
4. Do I need to set any setting for stp in switches ?
Please reply one by one thanks.
I am using 192.168.0.1 255.255.255.0 IP range.
Best Regards,
Highlighted
Advocate
Hi Aamir, STP is already set
Hi Aamir, STP is already set up by default. Even if you create a network loop a port is going to go in to blocking.
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
