CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
997
Francois PICARD
Beginner
SRW 2024 v1.1 - frw 1.2.2b (Qos Mode ? advanced)
Hello
SRW2024 v1.1
Model Name  SRW2024
Hardware Version  00.03.11
Boot Version  1.0.1
Firmware Version  1.2.2b
Hello, i would like to use Advance qos mode
I can select Qos Mode : Basic / Disable.
How select advanced mode QoS ?
The documentation
http://www.cisco.com/en/US/docs/switches/lan/csbms/srw2048/administration/guide/SRW-US_v10_UG_A-Web.pdf
page 40 (in the documentation):
The CoS Settings screen has two areas, CoS Settings and CoS to Queue.
QoS Mode Indicates if QoS is enabled on the interface.
The possible values are:
    •• Disable Disables QoS on the interface.
    •• Basic Enables QoS on the interface.
    •• Advanced Enables Advanced mode QoS on the interface. This feature has been added to version 1.2 of the SRW2024/SRW2016 and version 1.1 of the SRW224G4/SRW248G4.
SRW2024 Firmware Revision History :
http://www.cisco.com/en/US/docs/switches/lan/csbms/srw2016_srw2024/release/notes/SRW2016-24-hw1.3_RN_v1.2.2b-tm.pdf
5. QoS --> Advanced Mode
(a) When configuring a policy with police - exceeded action - out of profile dscp, the policy must have an action: trust cos-dscp or set dscp. If you configure a policy with police - exceeded action - out of profile dscp without an action - the device configures the action to trust cos-dscp. If you configure a policy with police - exceeded action - out of profile dscp with an action set cos/queue, the device configures the action to set dscp 0.
Best regards
Thank you
1 REPLY 1
Hello Mr Picard,
I see that you have a SRW2024 v1.1.
Unfortunately at this point is not possible to use the Advance Qos mode on this kind of devices.
As you can see on the documentation found.
This option is only available for equipmets from the version 1.2 onwards
