03-25-2014 11:21 PM
So I decided to purchase a SRW2048 for a switch and now that I have it the previous owner must of had changed up the port and web gui ip since i cannot console in
I use Hyper Terminal with these settings
Solved! Go to Solution.
03-26-2014 09:47 AM
Right, you bought a null modem cable wich is common, but according to the thread I linked to you will need a straight cable to console into this switch.
03-26-2014 09:18 AM
Hi Victor, you probably need to find or make a different cable than you are used to. See here:
http://community.linksys.com/t5/Switches/Console-cable/m-p/85004?query.id=92299
03-26-2014 09:39 AM
03-26-2014 09:47 AM
03-26-2014 10:07 AM
Ohhhhh. Okay so Im assuming I need this one then?
http://www.monoprice.com/Product?c_id=102&cp_id=10212&cs_id=1021201&p_id=448&seq=1&format=2
03-26-2014 12:41 PM
Yes, that look right to me.
03-26-2014 03:01 PM
Thank you very much!!!
That did the trick and now when I connect to console I can see everything! :)
Thanks.
/RESOLVED
