04-09-2011 01:50 AM
since a few days my srw2048 are flodding my logs (one week: 119.229 for about 40 switches):
%UPNP-W-DBOVERFLOW: UPnP retransmission DB overflow.#015
What does that message mean? How can I fix it?
Solved! Go to Solution.
04-12-2011 05:55 AM
Hi Jens,
Thank you for the log. As you indicated, you have a large network with a lot of devices.
The SRW device has an internal memory pool that keeps UPnP messages for retransmission.
The %UPNP-W-DBOVERFLOW: UPnP retransmission DB overflow messages indicate that this memory pool has been exhausted.
This scenario might occur in networks with lots of UPnP devices and many UPnP control points each requesting UPnP reports from the SRW device.
For example if you have a network with many PCs running Win XP and UPnP UI installed, the device might get many queries and utilize 100% of this
memory pool.
As far as we can see, the behavior is as designed - overflow occurs when too many messages are received within a short period of time.
There is no memory leak, and after the en-queued messages were handled, new requests are accepted by the device.
To summarize, these log messages are normal and do not adversely affect the performance of the switch.
The switch should continue to filter and forward frames as configured.
However, you could verify whether all this UPnP traffic is necessary on the network and eventually reconfigure the hosts generating it.
Please let me know if you have any other questions.
Best regards,
Nico Muselle
Sr. Network Engineer - CCNA
04-11-2011 12:23 AM
Hello Jens,
Thank you for participating in the Small Business support community. My name is Nico Muselle from Cisco Sofia SBSC.
These log messages mean that some device in your network is flooding broadcast UPnP messages over the switches in such a way that the switch(es) doesn't (don't) have time to handle all of them, thus an overflow occurs.
Going back to the moment these messages started to appear, has anything changed on the network, has any device been added at that moment that could have caused this UPnP flooding ? The easiest way to solve this is if you know where the traffic is generated and configure this particular device in such a way that it stops flooding the network with UPnP packets.
If you don't know what device causes it, the best thing to do is to monitor the network traffic for UPnP messages using Wireshark and determine there what is the source IP of these packets, to be able to put a halt to it. This way, you could also decide what is the destination multicast IP address and eventually implement an ACL on the source port to block this traffic if you cannot turn it of on the device causing it.
Hope this helped,
Best regards,
Nico Muselle
04-11-2011 08:06 AM
Hello Nico,
the change is simple: we've changed the backbone from Summit to Cisco
But the network is large and it could also be another cause...
Now the message appears every few minutes:
11-Apr-2011 16:49:56 %UPNP-W-DBOVERFLOW: UPnP retransmission DB overflow.
11-Apr-2011 16:51:20 %UPNP-W-DBOVERFLOW: UPnP retransmission DB overflow.
11-Apr-2011 16:51:25 %UPNP-W-DBOVERFLOW: UPnP retransmission DB overflow.
I've monitored the connection to one Linksys and the six SSDP-packets before the syslog packet (DB-Overflow) are all from the same switch!
No. Time Source Destination Protocol Info
101 205.360290 141.100.45.144 239.255.255.250 SSDP NOTIFY * HTTP/1.1
105 205.701177 141.100.45.144 239.255.255.250 SSDP NOTIFY * HTTP/1.1
106 206.385191 141.100.45.144 239.255.255.250 SSDP NOTIFY * HTTP/1.1
107 206.539223 141.100.45.144 239.255.255.250 SSDP NOTIFY * HTTP/1.1
108 206.916588 141.100.45.144 239.255.255.250 SSDP NOTIFY * HTTP/1.1
115 207.303573 141.100.56.155 239.255.255.250 SSDP NOTIFY * HTTP/1.1
118 207.402520 141.100.56.155 239.255.255.250 SSDP NOTIFY * HTTP/1.1
119 207.502300 141.100.56.155 239.255.255.250 SSDP NOTIFY * HTTP/1.1
121 207.668939 141.100.56.151 239.255.255.250 SSDP NOTIFY * HTTP/1.1
122 207.669066 141.100.56.151 239.255.255.250 SSDP NOTIFY * HTTP/1.1
129 207.868867 141.100.56.151 239.255.255.250 SSDP NOTIFY * HTTP/1.1
130 207.868985 141.100.56.151 239.255.255.250 SSDP NOTIFY * HTTP/1.1
139 208.132214 141.100.45.144 239.255.255.250 SSDP NOTIFY * HTTP/1.1
142 208.701495 141.100.45.144 239.255.255.250 SSDP NOTIFY * HTTP/1.1
153 209.539849 141.100.45.144 239.255.255.250 SSDP NOTIFY * HTTP/1.1
157 209.933810 141.100.45.144 239.255.255.250 SSDP NOTIFY * HTTP/1.1
158 210.149266 141.100.56.134 239.255.255.250 SSDP NOTIFY * HTTP/1.1
160 210.349201 141.100.56.134 239.255.255.250 SSDP NOTIFY * HTTP/1.1
162 211.032589 141.100.56.153 239.255.255.250 SSDP NOTIFY * HTTP/1.1
163 211.155807 141.100.45.144 239.255.255.250 SSDP NOTIFY * HTTP/1.1
164 211.358384 141.100.45.144 239.255.255.250 SSDP NOTIFY * HTTP/1.1
166 211.722344 141.100.45.144 239.255.255.250 SSDP NOTIFY * HTTP/1.1
188 217.398020 141.100.56.155 239.255.255.250 SSDP NOTIFY * HTTP/1.1
190 218.435290 141.100.56.154 239.255.255.250 SSDP NOTIFY * HTTP/1.1
191 218.534035 141.100.56.154 239.255.255.250 SSDP NOTIFY * HTTP/1.1
192 218.634133 141.100.56.154 239.255.255.250 SSDP NOTIFY * HTTP/1.1
216 221.774000 141.100.56.150 239.255.255.250 SSDP NOTIFY * HTTP/1.1
217 221.829395 141.100.56.149 239.255.255.250 SSDP NOTIFY * HTTP/1.1
218 221.872692 141.100.56.150 239.255.255.250 SSDP NOTIFY * HTTP/1.1
219 221.875238 141.100.41.6 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
221 221.928149 141.100.56.149 239.255.255.250 SSDP NOTIFY * HTTP/1.1
222 221.972684 141.100.56.150 239.255.255.250 SSDP NOTIFY * HTTP/1.1
223 222.028106 141.100.56.149 239.255.255.250 SSDP NOTIFY * HTTP/1.1
229 224.885628 141.100.41.6 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
242 226.683579 141.100.56.132 239.255.255.250 SSDP NOTIFY * HTTP/1.1
243 226.764922 192.168.95.49 239.255.255.250 SSDP NOTIFY * HTTP/1.1
244 226.782607 141.100.56.132 239.255.255.250 SSDP NOTIFY * HTTP/1.1
245 226.882258 141.100.56.132 239.255.255.250 SSDP NOTIFY * HTTP/1.1
248 227.896089 141.100.41.6 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
250 228.529551 141.100.56.154 239.255.255.250 SSDP NOTIFY * HTTP/1.1
256 228.727646 141.100.56.140 239.255.255.250 SSDP NOTIFY * HTTP/1.1
257 228.729795 141.100.56.154 239.255.255.250 SSDP NOTIFY * HTTP/1.1
258 228.826343 141.100.56.140 239.255.255.250 SSDP NOTIFY * HTTP/1.1
259 228.926323 141.100.56.140 239.255.255.250 SSDP NOTIFY * HTTP/1.1
263 229.265237 141.100.59.245 239.255.255.250 SSDP NOTIFY * HTTP/1.1
273 230.920195 141.100.41.6 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
276 231.868136 141.100.56.150 239.255.255.250 SSDP NOTIFY * HTTP/1.1
277 231.923627 141.100.56.149 239.255.255.250 SSDP NOTIFY * HTTP/1.1
278 232.068015 141.100.56.150 239.255.255.250 SSDP NOTIFY * HTTP/1.1
286 233.917088 141.100.41.6 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
312 236.412717 141.100.56.158 239.255.255.250 SSDP NOTIFY * HTTP/1.1
314 236.511372 141.100.56.158 239.255.255.250 SSDP NOTIFY * HTTP/1.1
316 236.611358 141.100.56.158 239.255.255.250 SSDP NOTIFY * HTTP/1.1
317 236.777669 141.100.56.132 239.255.255.250 SSDP NOTIFY * HTTP/1.1
318 236.927583 141.100.41.6 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
319 236.977586 141.100.56.132 239.255.255.250 SSDP NOTIFY * HTTP/1.1
324 238.821678 141.100.56.140 239.255.255.250 SSDP NOTIFY * HTTP/1.1
371 242.882012 141.100.56.131 239.255.255.250 SSDP NOTIFY * HTTP/1.1
372 242.980577 141.100.56.131 239.255.255.250 SSDP NOTIFY * HTTP/1.1
374 243.080575 141.100.56.131 239.255.255.250 SSDP NOTIFY * HTTP/1.1
375 243.091859 141.100.45.144 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
395 246.090028 141.100.45.144 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
396 246.506784 141.100.56.158 239.255.255.250 SSDP NOTIFY * HTTP/1.1
406 249.091234 141.100.45.144 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
413 252.135855 141.100.45.144 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
419 252.976015 141.100.56.131 239.255.255.250 SSDP NOTIFY * HTTP/1.1
442 254.593505 141.100.56.159 239.255.255.250 SSDP NOTIFY * HTTP/1.1
450 254.692154 141.100.56.159 239.255.255.250 SSDP NOTIFY * HTTP/1.1
463 254.792126 141.100.56.159 239.255.255.250 SSDP NOTIFY * HTTP/1.1
470 255.136829 141.100.45.144 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
471 255.154779 141.100.56.163 239.255.255.250 SSDP NOTIFY * HTTP/1.1
475 255.253509 141.100.56.163 239.255.255.250 SSDP NOTIFY * HTTP/1.1
476 255.353435 141.100.56.163 239.255.255.250 SSDP NOTIFY * HTTP/1.1
481 256.762488 192.168.95.49 239.255.255.250 SSDP NOTIFY * HTTP/1.1
486 258.135885 141.100.45.144 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
494 259.262393 141.100.59.245 239.255.255.250 SSDP NOTIFY * HTTP/1.1
530 264.687474 141.100.56.159 239.255.255.250 SSDP NOTIFY * HTTP/1.1
532 265.248810 141.100.56.163 239.255.255.250 SSDP NOTIFY * HTTP/1.1
536 266.838463 141.100.56.162 239.255.255.250 SSDP NOTIFY * HTTP/1.1
537 266.937156 141.100.56.162 239.255.255.250 SSDP NOTIFY * HTTP/1.1
538 267.037133 141.100.56.162 239.255.255.250 SSDP NOTIFY * HTTP/1.1
600 271.621663 141.100.56.152 239.255.255.250 SSDP NOTIFY * HTTP/1.1
601 271.720418 141.100.56.152 239.255.255.250 SSDP NOTIFY * HTTP/1.1
602 271.820393 141.100.56.152 239.255.255.250 SSDP NOTIFY * HTTP/1.1
614 276.683415 141.100.56.146 239.255.255.250 SSDP NOTIFY * HTTP/1.1
615 276.782179 141.100.56.146 239.255.255.250 SSDP NOTIFY * HTTP/1.1
616 276.882061 141.100.56.146 239.255.255.250 SSDP NOTIFY * HTTP/1.1
617 276.932588 141.100.56.162 239.255.255.250 SSDP NOTIFY * HTTP/1.1
621 278.696584 141.100.56.145 239.255.255.250 SSDP NOTIFY * HTTP/1.1
622 278.795278 141.100.56.145 239.255.255.250 SSDP NOTIFY * HTTP/1.1
623 278.855046 141.100.56.147 239.255.255.250 SSDP NOTIFY * HTTP/1.1
624 278.895271 141.100.56.145 239.255.255.250 SSDP NOTIFY * HTTP/1.1
625 278.958770 141.100.56.147 239.255.255.250 SSDP NOTIFY * HTTP/1.1
626 279.056438 141.100.56.147 239.255.255.250 SSDP NOTIFY * HTTP/1.1
666 281.715772 141.100.56.152 239.255.255.250 SSDP NOTIFY * HTTP/1.1
723 286.760054 192.168.95.49 239.255.255.250 SSDP NOTIFY * HTTP/1.1
724 286.777460 141.100.56.146 239.255.255.250 SSDP NOTIFY * HTTP/1.1
725 286.977568 141.100.56.146 239.255.255.250 SSDP NOTIFY * HTTP/1.1
732 288.790670 141.100.56.145 239.255.255.250 SSDP NOTIFY * HTTP/1.1
733 288.954103 141.100.56.147 239.255.255.250 SSDP NOTIFY * HTTP/1.1
735 289.259514 141.100.59.245 239.255.255.250 SSDP NOTIFY * HTTP/1.1
742 290.671463 141.100.45.144 239.255.255.250 UDP Source port: 51902 Destination port: ws-discovery
743 290.951295 141.100.45.144 239.255.255.250 UDP Source port: 51902 Destination port: ws-discovery
744 290.952049 141.100.45.144 239.255.255.250 UDP Source port: 51902 Destination port: ws-discovery
746 291.139758 141.100.45.144 239.255.255.250 UDP Source port: 51902 Destination port: ws-discovery
748 291.253799 141.100.45.144 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
761 293.812719 141.100.56.148 239.255.255.250 SSDP NOTIFY * HTTP/1.1
762 293.852781 141.100.51.36 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
764 293.911240 141.100.56.148 239.255.255.250 SSDP NOTIFY * HTTP/1.1
766 294.011436 141.100.56.148 239.255.255.250 SSDP NOTIFY * HTTP/1.1
779 294.254634 141.100.45.144 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
787 295.854701 141.100.51.36 239.255.255.250 UDP Source port: 50523 Destination port: ws-discovery
788 295.877546 141.100.51.36 239.255.255.250 UDP Source port: 50523 Destination port: ws-discovery
790 296.053962 141.100.51.36 239.255.255.250 UDP Source port: 50523 Destination port: ws-discovery
791 296.059235 141.100.51.36 239.255.255.250 UDP Source port: 50523 Destination port: ws-discovery
792 296.083245 141.100.51.36 239.255.255.250 UDP Source port: 50523 Destination port: ws-discovery
793 296.305851 141.100.51.36 239.255.255.250 UDP Source port: 50523 Destination port: ws-discovery
797 296.836563 141.100.51.36 239.255.255.250 UDP Source port: 50523 Destination port: ws-discovery
798 296.863173 141.100.51.36 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
800 296.936697 141.100.51.36 239.255.255.250 UDP Source port: 50523 Destination port: ws-discovery
804 297.254320 141.100.45.144 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
815 299.862156 141.100.51.36 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
832 300.283348 141.100.45.144 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
844 302.861998 141.100.51.36 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
846 303.290189 141.100.45.144 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
847 303.906743 141.100.56.148 239.255.255.250 SSDP NOTIFY * HTTP/1.1
854 305.842704 141.100.56.161 239.255.255.250 SSDP NOTIFY * HTTP/1.1
855 305.941448 141.100.56.161 239.255.255.250 SSDP NOTIFY * HTTP/1.1
856 306.041413 141.100.56.161 239.255.255.250 SSDP NOTIFY * HTTP/1.1
858 306.290111 141.100.45.144 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
867 309.057335 141.100.66.230 239.255.255.250 IGMP V1 Membership Report
870 309.319573 141.100.45.144 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
877 312.326966 141.100.45.144 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
886 313.546432 141.100.56.164 239.255.255.250 SSDP NOTIFY * HTTP/1.1
887 313.645750 141.100.56.164 239.255.255.250 SSDP NOTIFY * HTTP/1.1
888 313.745170 141.100.56.164 239.255.255.250 SSDP NOTIFY * HTTP/1.1
913 315.332112 141.100.45.144 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
916 315.936973 141.100.56.161 239.255.255.250 SSDP NOTIFY * HTTP/1.1
917 316.136806 141.100.56.161 239.255.255.250 SSDP NOTIFY * HTTP/1.1
923 316.757573 192.168.95.49 239.255.255.250 SSDP NOTIFY * HTTP/1.1
933 319.256525 141.100.59.245 239.255.255.250 SSDP NOTIFY * HTTP/1.1
961 323.640702 141.100.56.164 239.255.255.250 SSDP NOTIFY * HTTP/1.1
969 324.652615 141.100.56.135 239.255.255.250 SSDP NOTIFY * HTTP/1.1
970 324.751275 141.100.56.135 239.255.255.250 SSDP NOTIFY * HTTP/1.1
971 324.851151 141.100.56.135 239.255.255.250 SSDP NOTIFY * HTTP/1.1
982 327.831707 141.100.56.137 239.255.255.250 SSDP NOTIFY * HTTP/1.1
983 327.930281 141.100.56.137 239.255.255.250 SSDP NOTIFY * HTTP/1.1
986 328.030262 141.100.56.137 239.255.255.250 SSDP NOTIFY * HTTP/1.1
1011 334.746697 141.100.56.135 239.255.255.250 SSDP NOTIFY * HTTP/1.1
1044 337.925554 141.100.56.137 239.255.255.250 SSDP NOTIFY * HTTP/1.1
1045 338.125423 141.100.56.137 239.255.255.250 SSDP NOTIFY * HTTP/1.1
1054 339.455847 141.100.56.165 239.255.255.250 SSDP NOTIFY * HTTP/1.1
1055 339.554570 141.100.56.165 239.255.255.250 SSDP NOTIFY * HTTP/1.1
1056 339.654529 141.100.56.165 239.255.255.250 SSDP NOTIFY * HTTP/1.1
1356 343.476047 141.100.56.151 141.100.56.1 Syslog LOCAL7.INFO: %AAA-I-CONNECT: User CLI session for user admin over ssh , source 141.100.45.184 destination 0.0.0.0 ACCEPTED\r\n
1427 343.909078 141.100.56.151 141.100.56.1 Syslog LOCAL7.INFO: %AAA-I-DISCONNECT: User CLI session for user admin over ssh , source 141.100.45.184 destination 0.0.0.0 TERMINATED. The Telnet/SSH session may still be connected.\r\n
1589 346.755156 192.168.95.49 239.255.255.250 SSDP NOTIFY * HTTP/1.1
1602 349.253658 141.100.59.245 239.255.255.250 SSDP NOTIFY * HTTP/1.1
1625 349.553338 141.100.56.165 239.255.255.250 SSDP NOTIFY * HTTP/1.1
1729 351.804673 141.100.56.151 141.100.56.1 Syslog LOCAL7.INFO: %AAA-I-CONNECT: User CLI session for user admin over ssh , source 141.100.45.184 destination 141.100.56.151 ACCEPTED\r\n
1824 356.003044 141.100.45.144 239.255.255.250 UDP Source port: 51902 Destination port: ws-discovery
1825 356.127434 141.100.45.144 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
1835 359.127108 141.100.45.144 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
1855 362.127264 141.100.45.144 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
1866 365.237880 141.100.45.144 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
1877 368.235508 141.100.45.144 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
1882 369.122688 141.100.51.36 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
1883 369.123106 141.100.51.36 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
1892 370.642313 141.100.56.129 239.255.255.250 SSDP NOTIFY * HTTP/1.1
1893 370.740856 141.100.56.129 239.255.255.250 SSDP NOTIFY * HTTP/1.1
1895 370.840903 141.100.56.129 239.255.255.250 SSDP NOTIFY * HTTP/1.1
1897 371.232749 141.100.45.144 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
1920 372.122675 141.100.51.36 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
1921 372.122880 141.100.51.36 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
1983 375.122409 141.100.51.36 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
1984 375.122617 141.100.51.36 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
2159 376.752671 192.168.95.49 239.255.255.250 SSDP NOTIFY * HTTP/1.1
2168 379.250746 141.100.59.245 239.255.255.250 SSDP NOTIFY * HTTP/1.1
2191 380.736276 141.100.56.129 239.255.255.250 SSDP NOTIFY * HTTP/1.1
2192 380.936203 141.100.56.129 239.255.255.250 SSDP NOTIFY * HTTP/1.1
3752 390.344300 141.100.56.160 239.255.255.250 SSDP NOTIFY * HTTP/1.1
3760 390.443013 141.100.56.160 239.255.255.250 SSDP NOTIFY * HTTP/1.1
3763 390.542998 141.100.56.160 239.255.255.250 SSDP NOTIFY * HTTP/1.1
3809 400.438399 141.100.56.160 239.255.255.250 SSDP NOTIFY * HTTP/1.1
3833 406.750251 192.168.95.49 239.255.255.250 SSDP NOTIFY * HTTP/1.1
3846 409.247825 141.100.59.245 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4174 436.005987 141.100.66.230 239.255.255.250 IGMP V1 Membership Report
4184 436.747788 192.168.95.49 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4193 439.244954 141.100.59.245 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4283 453.051624 141.100.51.129 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
4285 453.095653 141.100.51.129 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
4286 453.243196 141.100.51.129 239.255.255.250 UDP Source port: 62803 Destination port: ws-discovery
4287 453.468219 141.100.51.129 239.255.255.250 UDP Source port: 62803 Destination port: ws-discovery
4292 456.057690 141.100.51.129 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
4294 456.104440 141.100.51.129 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
4307 459.068319 141.100.51.129 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
4309 459.115023 141.100.51.129 239.255.255.250 SSDP M-SEARCH * HTTP/1.1
4348 466.745363 192.168.95.49 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4358 469.242065 141.100.59.245 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4362 470.133310 141.100.56.144 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4363 470.232108 141.100.56.144 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4364 470.332072 141.100.56.144 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4370 471.710112 141.100.56.141 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4373 471.808848 141.100.56.141 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4382 471.908798 141.100.56.141 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4396 472.742651 141.100.56.142 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4398 472.841391 141.100.56.142 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4400 472.941362 141.100.56.142 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4572 477.966532 141.100.56.143 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4573 478.065229 141.100.56.143 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4574 478.165196 141.100.56.143 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4582 478.535704 141.100.56.133 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4584 478.634316 141.100.56.133 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4585 478.734285 141.100.56.133 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4600 480.227454 141.100.56.144 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4604 480.427356 141.100.56.144 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4609 481.500188 141.100.56.139 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4610 481.595498 141.100.56.139 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4611 481.694561 141.100.56.139 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4612 481.804233 141.100.56.141 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4615 482.836765 141.100.56.142 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4616 482.866500 141.100.56.156 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4618 482.965191 141.100.56.156 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4619 483.065187 141.100.56.156 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4620 483.096820 141.100.56.157 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4621 483.195569 141.100.56.157 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4622 483.295541 141.100.56.157 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4651 488.060591 141.100.56.143 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4652 488.260502 141.100.56.143 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4654 488.629678 141.100.56.133 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4669 490.766789 141.100.56.130 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4670 490.865536 141.100.56.130 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4671 490.965614 141.100.56.130 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4674 491.590907 141.100.56.139 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4680 492.960616 141.100.56.156 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4681 493.190906 141.100.56.157 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4682 493.390803 141.100.56.157 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4707 496.742904 192.168.95.49 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4710 497.733654 141.100.56.151 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4711 497.734934 141.100.56.151 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4717 497.833468 141.100.56.151 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4718 497.833590 141.100.56.151 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4721 497.933445 141.100.56.151 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4722 497.933570 141.100.56.151 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4723 497.954451 141.100.56.151 141.100.56.1 Syslog LOCAL7.WARNING: %UPNP-W-DBOVERFLOW: UPnP retransmission DB overflow.\r\n
4739 499.239144 141.100.59.245 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4755 500.217702 141.100.56.134 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4757 500.316429 141.100.56.134 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4761 500.416633 141.100.56.134 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4765 500.860867 141.100.56.130 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4767 501.099394 141.100.56.153 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4769 501.198067 141.100.56.153 239.255.255.250 SSDP NOTIFY * HTTP/1.1
4770 501.298035 141.100.56.153 239.255.255.250 SSDP NOTIFY * HTTP/1.1
04-12-2011 05:55 AM
Hi Jens,
memory pool.
Best regards,
Nico Muselle
04-12-2011 11:50 AM
ok, thank you - I'll filter the log entries
04-13-2011 12:24 AM
Welcome Jens, glad I could clarify this for you
Nico
11-02-2011 05:27 PM
Nico - since you were able to clarify things for Jens, please allow me to humbly ask for a bit of additional clarification as well...
What Jens is experiencing seems to be the same thing that we've suffered with at my office for a few years now (~2008), and has plagued many others going back even further (2006).
Please see these two links:
https://supportforums.cisco.com/message/3104089#3104089
http://homecommunity.cisco.com/t5/Switches/SRW2024-Log-message-Gen-Troubleshooting/td-p/15279
I have two small problems with your answer though:
The SRW device has an internal memory pool that keeps UPnP messages for retransmission.The %UPNP-W-DBOVERFLOW: UPnP retransmission DB overflow messages indicate that this memory pool has been exhausted.
memory pool.
In my office, we only have 30 computers, 6 printers, a router and a firewall, yet this issue has been a chronic problem for us. I've disabled UPnP on all of the peripherals, but with the way that things have progressed in Windows from XP to Vista to 7, disabling UPnP on the workstations is becoming less of an option because functionality is beginning to depend on it, like Network Discovery. Didn't need UPnP for years to see the whole network in Windows, now the two go hand-in-hand, but that's a complaint for a different company though. Is 30-40 devices enough to be considered "lots of UPnP devices and many UPnP control points"?
I think that when I called Cisco about this problem a few years back they said the same thing, and I accepted it, but later found that this was most definitely not the case. What actually happens is that once the buffer overflows, the switch struggles to keep up and gradually runs out of memory, starts having issues correctly processing legitimate non-UPnP traffic (leading to users complaining about slow logins, dropped database connections, corrupted print jobs, and any number of other issues). Rebooting the switch inevitably seems to "fix" the problem, because it forces the buffer to reset and dumps the pending queue, thus giving the switch a "clean-slate" and allowing it to focus on the real traffic... while UPnP starts backing up again... Or, at least that's how it behaves in my office - here's a log excerpt from just a little bit ago:
Log Index | Log Time | Severity | Description | |
1 | 2147416320 | 02-Nov-2011 17:55:31 | Informational | %AAA-I-CONNECT: New http connection for user admin, source 192.168.16.73 destination 192.168.16.145 ACCEPTED |
2 | 2147416321 | 02-Nov-2011 17:53:40 | Warning | %UPNP-W-DBOVERFLOW: UPnP retransmission DB overflow. |
3 | 2147416322 | 02-Nov-2011 17:53:40 | Debug | %OS-D-MEMORY: No free memory: size = 364, pool = UPnP, task = UPNP |
4 | 2147416323 | 02-Nov-2011 17:53:40 | Warning | %UPNP-W-DBOVERFLOW: UPnP retransmission DB overflow. |
5 | 2147416324 | 02-Nov-2011 17:53:40 | Debug | %OS-D-MEMORY: No free memory: size = 340, pool = UPnP, task = UPNP |
6 | 2147416325 | 02-Nov-2011 17:48:42 | Warning | %UPNP-W-DBOVERFLOW: UPnP retransmission DB overflow. |
7 | 2147416326 | 02-Nov-2011 17:48:42 | Debug | %OS-D-MEMORY: No free memory: size = 364, pool = UPnP, task = UPNP |
8 | 2147416327 | 02-Nov-2011 17:48:42 | Warning | %UPNP-W-DBOVERFLOW: UPnP retransmission DB overflow. |
9 | 2147416328 | 02-Nov-2011 17:48:42 | Debug | %OS-D-MEMORY: No free memory: size = 340, pool = UPnP, task = UPNP |
10 | 2147416329 | 02-Nov-2011 17:43:42 | Warning | %UPNP-W-DBOVERFLOW: UPnP retransmission DB overflow. |
11 | 2147416330 | 02-Nov-2011 17:43:42 | Debug | %OS-D-MEMORY: No free memory: size = 364, pool = UPnP, task = UPNP |
12 | 2147416331 | 02-Nov-2011 17:43:41 | Warning | %UPNP-W-DBOVERFLOW: UPnP retransmission DB overflow. |
I have a few follow-up questions/suggestions, if you don't mind:
The first is obvious - how do I make it stop? Power-cycling it every few months to reset it is really getting old and, arguably, shouldn't be necessary - even you said it should keep working fine and the errors can be safely ignored. I can't kill UPnP/SSDP on my Windows boxes because, well, it's pretty much part of Windows now. Plus, doing so really shouldn't be any more necessary than power-cycling it - why doesn't it handle UPnP traffic the same way it handles everything else that broad/multicasts?
When I called in about this issue, the tech (it took several before anyone had any idea what the errors meant) said to use WireShark to figure out where the UPnP broadcasts were coming from and disable it on that device, or create an ACL to block it at the switch, which is essentially the same answer you gave. I don't really have time to capture and process and sniff around to find the culprit - how would I go about creating an ACL to block all UPnP traffic from entering the switch (but not kill all other broadcast traffic)? I can't tell you how much I'd appreciate it if you could give me just that small bit of information (and ideally add it to the knowledge base for everyone else who's tired of this problem to refer to)...
I tried to figure it out - went to the ACL tab, made an IP-based ACL, Deny TCP Any 5000 Any Any, Deny UDP Any 1900 Any Any, but it doesn't seem to be doing anything at all.
I *really* hope you can help me put the final nail in this issue's coffin once and for all - I just received a brand new SRW2048 today to add to our network - unfortunately I assumed that new manufacturer/new hardware would have fixed this old headache.
Any help you can provide would be immensely appreciated. Thanks in advance.
