CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
4277
Highlighted
Beginner
SRW248G4 V1.1 unable to reset password
Hello
I have been fighting against this Lynksys cisco switch to be able to restore admin password, no success. Theorically, is just unplug and plug switch, press ESC and press option 3) Password Recovery Procedure. Then Enter and Enter and switch will boot normaly with admin/blank password, well, not work,.
*** Running  SW  Ver. 1.2.1b  Date  31-Aug-2006  Time  13:47:21 ***
HW version is 00.03.00
Base Mac address is: 00:1e:e5:1c:fd:eb
Dram size is  : 32M bytes
Dram first block size is  : 16969K bytes
Dram first PTR is  : 0xF6D840
Flash size is: 8M
01-Jan-2000 01:01:02 %CDB-I-LOADCONFIG: Loading startup configuration.
Device configuration:
Slot 1 - SRW48F4G HW Rev.  0.2
This is the output of part of switch's boot. Finally I get login home but I can't enter, no way. Anybody has any idea? I'm feel depressed T_T
Links
http://es.scribd.com/doc/56455711/11/Figure-2-8-Back-Panel-of-the-SRW248G4
http://www.boiseitoncall.com/diy-tech-tips/71-how-do-i-unlock-a-linksys-switch
http://www.dslreports.com/forum/remark,21280511
http://homecommunity.cisco.com/t5/Switches/How-to-reset-the-Switch/td-p/719/page/2
http://homecommunity.cisco.com/t5/Switches/Console-cable/m-p/85004?query.id=92299#M1038
http://pcsupport.about.com/od/cisco-default-passwords/a/srw2024-default-password.htm
http://homecommunity.cisco.com/t5/Switches/Hard-Reset-SRW2024/td-p/90329
https://supportforums.cisco.com/thread/2135933
http://www.cisco.com/en/US/docs/switches/lan/csbms/srw2048/administration/guide/SRW-US_v10_UG_A-Web.pdf
http://homecommunity.cisco.com/t5/Switches/restoring-factory-defaults-SRW2024/td-p/192643
http://www.opendreams.net/jesse/doc/linksys_srw_switch_password_recovery.txt
1 REPLY 1
Highlighted
Beginner
Hello
I have tried with two PCs, two different serial cables but no luck. I have read the forum hours and hours and I have found many people with my same issue but there is no clear response. This issue happens with a lot of Linksys of same family
Example:
https://supportforums.cisco.com/thread/2056233
Can someone help me a little, please?
Thanks!
