09-05-2015 01:49 AM
I need to stack 2 switches SG300-20. I want to know if it's possible to do it.
I did find something in the datasheet but i found this article (https://supportforums.cisco.com/discussion/11335951/sg300-unit-stacking-mode) and it seems that it's possible to do it.
Can you confirm that it's possible ?
Many thanks,
Nicolas
09-08-2015 05:44 AM
Stacking is not supported in the 300 series switches. Only the 500 series support stacking.
09-08-2015 05:52 AM
Thanks for your answer.
Have a good day,
Nicolas
09-09-2015 08:50 AM
In the case of, ...
I will buy SG500,
Wich shall i need to stack 2 * SG500 ?
Thanks a lot
Nicolas
09-09-2015 09:04 AM
The 500 series switches support hybrid stacking so you can use any of the switches from the datasheet below.
http://www.cisco.com/c/en/us/products/collateral/switches/small-business-500-series-stackable-managed-switches/c78-695646_data_sheet.html
The SG500X supports 10Gig stack links when using the supported stacking cables.
http://www.cisco.com/c/dam/en/us/products/collateral/switches/small-business-500-series-stackable-managed-switches/at_a_glance_c45-726838.pdf
09-11-2015 01:50 AM
Thanks a lot, Ruwyatt.
NIcolas
