07-07-2021 05:17 AM
i want to rout 3 Switches to 1 with the Vlan 400 with the IP 10.4.0.254/24
so i Static Routed on the 172.16.204.251 Switch Destination:10.4.0.0/24 Next Hop:172.16.254.40
and on the 172.16.254.40 Switch Destination: 10.4.0.0/24 Next Hop 172.16.204.251
then i wanted to do the same with 172.16.204.254 Switch but the 172.16.254.40 Switch says the Rout all ready exists
how can i Static Rout them if i cant creat the same Static Rout with another Next Hop?
MFG Sven
07-07-2021 05:33 AM
Can you post the syntax used here, which you got error, you need add different metric
07-08-2021 05:26 AM
Hello balaji.bandi,
thanks for the reply, i was told that the metric is how many hops the switch does.
MFG Sven
