switch 2960 and switch SG300
ngo duyen
we need inter-vlan routing between sg300- switch 2960 and router2900
Please see attach file.
and switch sg300 config (sg300_config.txt)
on switch 2960, we config:
int g1/0/1
switchport mode access
switchport access vlan 10
int g1/0/2
switchport access vlan 20
int g1/0/24
switchport mode trunk
the intervlan-routing between 2960 and router 2900 is ok,
But only vlan 10 can connect to router 2900
Please check the problem. I try to config access port on sg300 but I get some some errors.
ghostinthenet
Level 7
Level 7
The general configuration of the SG300 looks fine, but I'm wondering if the problem is upstream from there.
What output do you get from a "show vlan" and a "show interface trunk" on the Catalyst 2960?
Thanks Jody,
I think the cli of sg300 silimar with 2960
so interface of sg300 can config like this
interface gigabitethernet1
Is that right ?
As long as the native VLAN is untagged, you're good. Setting the switch port mode to access as you've indicated above will work, but will produce the same effect as having the switch port mode set to general with the VLAN untagged and the PVID set to match.
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
