07-17-2020 06:29 AM - edited 07-17-2020 06:30 AM
My have a PoE issus (not with a C3560CX), I have contacted TAC and they don't find SN in Data Base. They told me to contact my reseler but it is Cisco. No way to see!
What can I do?
Many thanks to your help.
Solved! Go to Solution.
07-20-2020 04:55 AM
Hello, I have created an issue.
TAC is working on my device.
I'll give you aupdates.
For information, all Cisco Switch are lifetime warranty.
Regards.
07-17-2020 10:12 AM
- Enter the serial number in this app : https://cway.cisco.com/sncheck/
If the device is found, confront TAC with the output and assure you have a legitimate device.
M.
07-17-2020 11:26 PM
07-17-2020 02:12 PM
can you post-show version and show inventory from the command line?
07-17-2020 11:23 PM
Hello BB,
PM send with these data.
Many thanks!
07-18-2020 02:12 AM
i got the PM and replied, but have you registered this device?
where did you purchase this one?
07-18-2020 02:39 AM
Many thanks to you.
It is not registered buy directly Cisco.
I hope we find something to do!
07-18-2020 04:42 AM - edited 07-18-2020 04:43 AM
if not you need to register or ask the vendor the one you purchased from? you purchased directly from cisco you mean?
is this brand new ? in general cisco only have 90days warranty, after that you looking for support you need to get a contract extended.
07-20-2020 04:55 AM
Regards.
