CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
736
Highlighted
Beginner
technical difference between SRW2008P-K9-EU SRW2008P-K9-AU
we are planning to buy 8 port POE switches, but from the market we foud the following models are available. one is costly and the other one is less costly. cheaper.
SRW2008P-K9-EU  is the costly model.
SRW2008P-K9-AU is the less cost model.
but we are worried if we buy SRW2008P-K9-AU what is the complications we are going to get.
so we would like to know the technical differences between  SRW2008P-K9-EU and SRW2008P-K9-AU. can any one pl support on this.
in india we work on 230V, 50Hz. so we would also like to know whether SRW2008P-K9-AU will work in our place or not.
thanks
Everyone's tags (2)
2 REPLIES 2
Rising star
EU means Europe with 230V 50 Hz power supply.
AU means Australia with 230V 50 Hz power supply.
The difference is probably in power cord and plug: http://en.wikipedia.org/wiki/Mains_electricity_by_country
Regards.
Beginner
Dear Daniele,
thanks for the reply. if this is the only difference, then we can change the powerr cord to suit to indian standard. will there be any other difference.
as per the above i can go with
SRW2008P-K9-AU and it will work same as
SRW2008P-K9-EU.
please confirm. thanks
