CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
296
Beginner
Telnet and SSH access for Switch 3560-CX
Hi All,
I want to access my switch (currently installed at a remote location) from my office and I want to enable both telnet and SSH access on it with the following credential:-
telnet password :- cisco 12345
ssh credentials :- username cisco privilege 15 secret cisco123
At the moment, when I am connecting through telnet its asking for a username and password and if I type SSH credentials, I can login but I dont want that, I want to use the telnet password to login, so please tell me the correct way to configure the switch.
Vis
Everyone's tags (1)
1 ACCEPTED SOLUTION
Advocate
Re: Telnet and SSH access for Switch 3560-CX
Hi @Visauk47
The login local command indicates that vty connections will use the local parameters (username + password) for logging.
If you want to use only the password of the vty lines, the login command must exist only, but that will disable the use of SSH.
Therefore, in order to use Telnet and SSH at the same time, you must use the parameters indicated locally (username + password).
4 REPLIES 4
Advocate
Hi @Visauk47
Can you share the current configuration of your switch?
Beginner
Sure, here is the config:
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname MCA1
boot-start-marker
boot-end-marker
logging buffered 16000
no logging console
enable secret 5 $1$Te8m$V6a6778d8m$Vsdfgdf
username cisco privilege 15 secret 5 $1$mwSWjkjrtyr$TRn0Rd
no aaa new-model
clock timezone NZT 12 0
clock summer-time NZT recurring 4 Sun Sep 2:00 1 Sun Apr 2:00
system mtu routing 1500
ip domain-name testrouter.com.au
ip name-server 1.1.1.1
vtp domain MCA1
vtp mode transparent
crypto pki trustpoint TP-self-signed-369206784
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-369206784
revocation-check none
rsakeypair TP-self-signed-369206784
crypto pki certificate chain TP-self-signed-369206784
certificate self-signed 01 nvram:IOS-Self-Sig#4.cer
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
vlan 42
name data
vlan 342
name voice
ip ssh version 2
interface GigabitEthernet0/1
switchport trunk native vlan 42
switchport trunk allowed vlan 42,342
switchport mode trunk
mls qos trust dscp
spanning-tree portfast trunk
spanning-tree bpduguard enable
interface GigabitEthernet0/2
mls qos trust dscp
interface GigabitEthernet0/3
mls qos trust dscp
interface GigabitEthernet0/4
mls qos trust dscp
interface GigabitEthernet0/5
mls qos trust dscp
interface GigabitEthernet0/6
mls qos trust dscp
interface GigabitEthernet0/7
mls qos trust dscp
interface GigabitEthernet0/8
mls qos trust dscp
interface GigabitEthernet0/9
mls qos trust dscp
interface GigabitEthernet0/10
description *** Uplink to Testrouter2 G1/0/17 ***
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan42
ip address 1.1.1.1 255.255.255.0
no ip route-cache
ip default-gateway 2.2.2.2
ip http server
ip http secure-server
snmp-server community ROUTER
snmp-server location *** Finance Building ***
snmp-server contact IS Network Group
snmp-server host 1.1.1.1 router sm
line con 0
exec-timeout 0 0
password 7 105E1C1702121C1F5656565C55
login
line vty 0 4
exec-timeout 5 0
password 7 044B1E5656565080824425A5948
login local
length 0
transport input telnet ssh
line vty 5 15
exec-timeout 5 0
login local
length 0
end
Advocate
Hi @Visauk47
Highlighted
Beginner
Thanks.
