CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
2424
Beginner
Trunking between 2960 and SG300-20, Error: %CDP-W-NATIVE_VLAN_MISMATCH
Hello experts,
I have create trunking between 2 switches 2960 and an SG300-20 but only on SG300 appear an error: "%CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected"
I attached the configuration file here for easy analysis,
Any help is appreciate
Best regards,
1 ACCEPTED SOLUTION
Beginner
Why assign ip address on vlan
Why assign ip address on vlan 97 (native) on SG300-20? Native doesn't need ip address or SVI (L3) see attached for sample configuration based on your attachments. Note: represent XXX with any number of your choice.
13 REPLIES 13
Enthusiast
Mismatch native vlan detected on which port ? Also could you upload the resulte from ( show cdp neighbors detail ) from any of the 2 switches. It will helps identify the mismatch occurance.
Beginner
Mismatch native vlan happened on gi19 &20 on SG300.
Here is the show cdp on switche SG300:
SG300-20#sho cdp nei detai
Device-ID: 2960_1
Advertisement version: 2
Platform: cisco WS-C2960-48TC-L
Capabilities: Switch IGMP
Interface: gi19, Port ID (outgoing port): FastEthernet0/37
Holdtime: 131
Version: Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(55
)SE10, RELEASE SOFTWARE (fc2)
Copyr
Duplex: full
Native VLAN: 97
SysObjectID: 0.0
Primary Management Address: IP 10.10.123.15,
Addresses:
          IP 10.10.123.15
Device-ID: 2960_1
Interface: gi20, Port ID (outgoing port): FastEthernet0/38
Holdtime: 130
Copyr
Duplex: full
Native VLAN: 97
SysObjectID: 0.0
Addresses:
          IP 10.10.123.15
On Switch 2960_1
2960_1#sho cdp nei de
Device ID: ****65a2
Entry address(es):
  IP address: 10.10.97.4
Platform: Cisco SG300-20 (PID:SRW2016-K9)-VSD,  Capabilities: Switch IGMP
Interface: FastEthernet0/37,  Port ID (outgoing port): gi19
Holdtime : 173 sec
Version :
1.4.0.88
advertisement version: 2
Native VLAN: 1
Duplex: full
Management address(es):
Device ID: ****65a2
Entry address(es):
Interface: FastEthernet0/38,  Port ID (outgoing port): gi20
Holdtime : 173 sec
Version :
1.4.0.88
Native VLAN: 1
Duplex: full
Any help is appreciated,
Best regards,
Beginner
can we use PAgP on your port
can we use PAgP on your port-channel? it is recommended to specify a protocol
on SG300, can we do hardcoding of "switchport mode trunk" on physical interface and on the port-channel?
as much as possible, trunking configuration should be the same at both side..
(including the allowed vlan)
Beginner
Beginner
Hello osahx1500,
Hello osahx1500,
You are right, you are save my life.
I tried as you recommended and its work perfect.
Basically, native Vlan in our system is Vlan1, so after that i reconfiguration to all interface to native Vlan1 on both of Sw 2960 and SG300 and it fine as expected.
Here is my configured, it may help if anyone have same issue:
Switch 2960:
interface Port-channel1
 switchport trunk allowed vlan 97,123
interface FastEthernet0/37
 description ## To_SG300 ##
 channel-group 1 mode on
interface FastEthernet0/38
On SG 300:
interface gigabitethernet19
interface gigabitethernet20
 negotiation 100f
 description To-Sw2960
 switchport trunk allowed vlan add 97,123
Thank you osahx1500 and everyone.
Best regards,
Beginner
Change native vlan 1 on On
Change native vlan 1 on On Switch 2960_1 to vlan 97 to match other side this should resolve native vlan mismatch
Beginner
Exactly, i had 1 more Switch L3 connected to 2960_1 and trunking already.
My topology is: Sw_L3 ---- trunking ----> Sw 2960_1 ---- trunking ----> SG300.
Here is the show cdp full on Switch 2960_1:
Device ID: Sw_L3_2
Entry address(es):
  IP address: 10.10.97.3
Platform: cisco WS-C4507R-E,  Capabilities: Router Switch IGMP
Interface: GigabitEthernet0/2,  Port ID (outgoing port): GigabitEthernet2/12
Holdtime : 147 sec
VTP Management Domain: ''''
Native VLAN: 1
Duplex: full
Device ID: Sw_L3_1
Entry address(es):
  IP address: 10.10.97.2
Interface: GigabitEthernet0/1,  Port ID (outgoing port): GigabitEthernet2/12
Holdtime : 173 sec
Native VLAN: 1
Duplex: full
Device ID: ****65a2
Entry address(es):
Holdtime : 151 sec
Version :
1.4.0.88
Native VLAN: 1
Duplex: full
Device ID: ****65a2
Entry address(es):
Holdtime : 151 sec
Version :
1.4.0.88
Native VLAN: 1
Duplex: full
Here is the config the interface on L3 that connected to Sw 2960_1:
SW_L3_1#sho run int gi2/12
Building configuration...
Current configuration : 149 bytes
interface GigabitEthernet2/12
 description ### To 2960_1_G0/1 ###
 switchport trunk allowed vlan 97,123,
end
Should i hardcoding assign IP address on Switch 2960_1 and SG300 on the same subnet?
Best regards,
Beginner
we can try the steps below in
we can try the steps below in order
1. shut down and remove config on port channel interface (if this one does not work, remove port channel interface)
2.shutdown and remove config on physical interface
3. reconfigure physical interface with switchport mode trunk,switchport native vlan, switchport allowed vlan, channel-group <n> mode active.
4.reconfigure or check configuration of port-channel interface. (if port channel interface is removed it is automatically created after specifying channel group under physical interface)
5. if configuration on port channel interface and on physical interface are the same, issue no shutdown command on port-channel interface.
6. do it on the other switch.
Beginner
Hi Trung,
Hi Trung,
try putting switchport trunk native vlan 97 on the physical interfaces of SG300 too.
Also please give me the result of show interfaces trunk.
Highlighted
Beginner
I also tried the switchport trunk native vlan 97 on SG300 but the packets transfer will be congested because ping is sometime timeout...
Based on the #show cdp output, I can see that 2960 is not applying the VLAN 97 as native in those ports. But, it helped me before to remove every configuration from ports that belong to a port channel and just configure them in the PortChannel interface. (like you did on the SG)
Miguel
Beginner
I'm unable to delete the Port channel on Sw SG300.
Do i need to press the reset button on the SG300 to delete Port Channel and after that reconfiguration?
Best regards,
SG is right. I think you can
SG is right. I think you can try changing the 2960 configuration to look like this:
interface FastEthernet0/1
 switchport access vlan 123
 switchport mode access
 spanning-tree portfast
