CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here to learn more.
Hello I have a stack of 6 switches and I want to add another over the gbit connector using fiber.
I already connected but I can acces the network from the new switch.
I don't have any issues on my Stack all resources are available
Do I need to do some special setup or connection to enable this?
Can be stacked like the others? I already usen the 2 stacking port can i Add another switch?
Hi Saulo, you may have up to 8 units in the stack. Just make sure the new box is on the same firmware then you may add to a free stack port
-Tom
Please mark answered for helpful posts
Thanks for your reply,
My unit is already using ports 24,48 can I connect another stack on 23 or 47 (23,47 are the same of ge3,ge4?).
or do I need to daisychain with another gbit using port GE2,GE1 ?
I believe the switch has only 2 stack ports, 24/48 are combo port to the ge1/ge2. you'd have to hang off a new switch somewhere else.
-Tom
