CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
543
Xu Zhang
Beginner
Unable to do scanning via network, suspect NetBIOS broadcast issue.
Hi Guys,
Help needed, as I am encountered a problem and I would like discuss it with all experts here. As shown in the network diagram attached, some inforamtion about the network as below:
1. All the VLAN gateway is on Core Switch
2. The Core Switch also functioned as a DHCP server
3. Trunk link between Core switch to Access Switch (SW1 & SW2)
4. There is Network Printer / Scanner connecting to SW2 that reside in VLAN 99.
The problem now is that the scanner not able to scan to host A & Host B that in VLAN 10, while host C working just fine. And all host in the network are able to print to the same printer. From the Wireshark packet capture (attached), I suspected the issue is caused by NetBIOS can't go through to different VLAN.
Now I really want to hear some good ideas from you to resolve this and many thanks in advanced.
0 REPLIES 0
