Unable to find boot code files for ESW switches.
bmbailey
Since ESW 500 Series firmware version 2.1.16 requires boot version 1.0.0.7 for 8-port ESW models and boot version 1.0.0.4 for 24-port and 48-port models, you may need to manually install or upgrade the boot code to ensure that the appropriate versions are used.
To download firmware and boot code files for ESW switches, go to www.cisco.com/go/esw500help, click the Resources tab, then click the Firmware link. A Cisco.com login is required.
Unable to find boot code at the listed URL.
2 Accepted Solutions
David Hornstein
Level 7
Level 7
Hi Brian,
I followed the link you mentioned, selected firmware  and rummaged around and found the bootcode.
see my screenshot below.
regards Dave
Thanks Dave.
And remember to use the Browser interface to the switch to install new bootcode. CCA does not do boot code.
5 Replies 5
David Hornstein
Level 7
Level 7
Hi Brian,
regards Dave
Thanks Dave.
Very odd, there must be a permission setting that prevents me from seeing the boot code.
I see, it's under the older code. Thanks!
Hi Brian,
Good stuff
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
