CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
1304
Highlighted
Beginner
unable to set dhcp relay address on interface of an SG350XG-48T
I'm not able to set specific DHCP relay addresses on interfaces. I can only set them globally from the CLI. When i add them to an interface, they default to global even though i'm on a specific interface. Is this a bug or am i doing something wrong?
Active-image: flash://system/images/image_tesla_hybrid_2.4.5.71_release_cisco_signed.bin
Version: 2.4.5.71
MD5 Digest: 2dff89efdb2a0ec2f9a2c414ff7d401c
Date: 04-Nov-2018
Time: 19:46:16
I've tried clearing out all globals and starting from scratch, but to no avail.
DHCP relay is Disabled
Option 82 is Disabled
Maximum number of supported VLANs without IP Address is 256
Number of DHCP Relays enabled on VLANs without IP Address is 0
DHCP relay is not configured on any port.
DHCP relay is enabled on Vlans: 1,20,50,60,70
Active:
Inactive: 1,20,50,60,70
Servers: 192.168.3.27 , 192.168.3.28
I tried to add 192.168.4.40 as a DHCP relay to interface VLAN 10:
cisco01(config)#interface vlan 10
cisco01(config-if)#ip dhcp relay address 192.168.4.40
cisco01(config-if)#ip dhcp relay enable
cisco01(config-if)#exit
cisco01(config)#exit
show run | inc dhcp shows the server got added to the global list instead of to the interface
Please advise... Thanks!
1 ACCEPTED SOLUTION
Highlighted
I tried downgrading. That did not work either.
I'm convinced this is a software bug OR the documentation is wrong. You should be able to set interface-specific DHCP relay addresses per the documentation. I can't get that to work no matter what i do, all servers added under an interface default to global in the config.
15 REPLIES 15
Highlighted
VIP Collaborator
I have dhcp relay enable without problem, may it is a bug os your system. You can apply it on physical interface and/or vlan interface.
DHCP relay is Enabled
DHCP relay is enabled on Vlans: 15-16,18,20-29
Active: 15-16,18,20-29
Inactive:
Servers: 172.20.14.196 , 172.20.14.198 , 172.20.14.211
Active-image: flash://system/images/image_tesla_hybrid_2.4.0.94.bin
Version: 2.4.0.94
MD5 Digest: 6f5be217100f34929986f2e93dd2d5e9
Date: 31-May-2018
Time: 02:39:58
Regards.
Jaderson Pessoa
*** Rate All Helpful Responses ***
Highlighted
VIP Collaborator
DHCP relay is Disabled    << your dhcp relay is disabled.
Active:
 try it:
SWC(config)#ip dhcp relay enable
SWC(config)#ip dhcp relay address x.x.x.x
interface vlan 20
interface vlan 50
interface vlan 60
interface vlan 70
Jaderson Pessoa
Highlighted
Jaderson,
Yes, I had that enabled before... sorry.
Active: 1,20,50,60,70
Inactive:
With .27 and .28 as global ip DHCP relay addresses, i'm not able to edit interface vlan 10 with a different specific DHCP relay address of 192.168.4.40. Any time I attempt to do so, it's simply added to the list of global DHCP relay servers.
The only thing different is you're running older code than I am. I'm wondering if I can back down to that release and IF that fixes the issue?
Highlighted
With .27 and .28 as global ip DHCP relay addresses, i'm not able to edit interface vlan 10 with a different specific DHCP relay address of 192.168.4.40. Any time I attempt to do so, it's simply added to the list of global DHCP relay servers.  << you cant apply diffrent dhcp server per interface, you can configure dhcp scope for vlan 10 and set it as globally too. Its wil work normally.
If you need that is restrited you can create a acl to filter the traffic.
The only thing different is you're running older code than I am. I'm wondering if I can back down to that release and IF that fixes the issue?   << its not necessary run downgrade.
Jaderson Pessoa
Highlighted
So, based upon what you're telling me - this is a limitation of the SG350/SG550 platform vs Cisco IOS
I know this is possible on Cisco IOS. According to the CLI docs for SG250XG this SHOULD be possible. The docs read that you can set interface specific ip dhcp server address <x.x.x.x> on a physical, vlan or Port-Channel.
Highlighted
This is what i would like to do:
1) remove global dhcp relay addresses
no ip dhcp relay address 192.168.3.27
no ip dhcp relay address 192.168.3.28
no ip dhcp relay address 192.168.4.40
2) add specific dhcp relay addresses to VLAN interfaces directly
interface vlan 1
exit
interface vlan 20
exit
interface vlan 50
exit
interface vlan 60
exit
interface vlan 70
exit
interface vlan 10
exit
Highlighted
Thats ok.
Just remove the servers from globally configuration, but leave it active status and add each server per interface or vlan.
check it: i hope that it can help you.
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-300-series-managed-switches/smb5567-configure-dynamic-host-configuration-protocol-dhcp-relay-set.html
Dont forget to mark as solved and helpful all post that were help you.
Jaderson Pessoa
Highlighted
Yes, i saw that URL and tried following that. Just doesn't seem to work.
Highlighted
Please, dont forget, when you apply it on interface. it is added automatically on global address. Doesn't matter if you remove it before, when you apply it on interface, it will be added at globally server as well. But it will be disponible just for that vlan.
Like it: interface vlan 26
name GUEST
ip address 172.20.23.1 255.255.255.0
ip dhcp relay address 172.20.14.196
Inactive:
Jaderson Pessoa
Highlighted
That makes no sense to me at all. I would expect:
global ip dhcp relay address <x.x.x.x> to apply to:
  • The entire switch if you globally enable ip dhcp relay
  • specific interfaces with ip dhcp relay enable
I would expect the ability to set interface-specific ip dhcp relay address <x.x.x.x> on specific VLAN, interface or port-channel and for that value(s) to override global settings. I would also expect that interface-specific dhcp relay addresses would NOT be added to the global list.
I expect that I should be able to add specific DHCP relay addresses that are specific to say VLAN 10, using a different value than what is stated globally.
I think this is a software bug.
Highlighted
Maybe, for my version it is working normally, At the same way there are any report bugs on your version, but you can try downgrade it to test.
Jaderson Pessoa
Highlighted
Given what you wrote, what does your configuration look like if you do:
show run int vlan 26
and do you see 172.20.14.196 show up in the global list of servers OR does is it indented underneath interface VLAN 26?
Highlighted
interface vlan 26
name GUEST
service-acl input REDEGUEST
if i remove it from global configuration and add dhcp address under interface.  Its add automatically to global configuration:
SWC#show ip dhcp relay
Inactive:
SWC(config)#no ip dhcp relay add 172.20.14.196
Inactive:
Servers: 172.20.14.198 , 172.20.14.211
SWC(config)#int vlan 26
SWC(config-if)#ip dhcp relay address 172.20.14.196
Inactive:
Please, dont forget of mark as solved and helpful all post the were help you.
thanks in advance.
Jaderson Pessoa
Highlighted
I'm sorry i didn't make myself clear. Instead of showing output from show ip dhcp relay can you provide the output from:
I'm curious if it's listed under the interface or global list in the config.
I know that they will all appear in the list of servers from the show ip dhcp relay, but i'm interested in knowing if you can put a custom server under an interface.
