update to 2.5.8.12 login problem
Peter __
Beginner
Beginner
Just a warning if you have special characters in your password at the start and update to 2.5.8.12 you may not be able to login.
Recommend you make another admin user and backup your config
Should you be locked out you have to reset login with cisco default change password Swap firmware Image to old 2.5.7.85 reboot then load your config login change your password then Swap firmware Image to new 2.5.8.12 and your up and running again.
9 Replies 9
marce1000
VIP Mentor VIP Mentor
VIP Mentor
          - Useful but you also may want to specify the device/model which gave you this problem.
 M.
SG350-10 10-Port Gigabit but guess other models will have the same problem
matthew1471
Beginner
Beginner
