06-14-2011 02:51 AM
For test I used 2 Switch that name "ESW X" and "ESW Y"
I have 2 network that I named "Network A" and "Network B"
I build 2 VLAN for each network that named Vlan 2 for Network A and Vlan 3 for Network B, I don't use Vlan 1 because it's the default Vlan
Configuration ESW X:
port e1 : ACCESS PORT on UNTTAGGED Vlan 2
port e2 : ACCESS PORT on UNTTAGGED Vlan 2
port e3 : ACCESS PORT on UNTTAGGED Vlan 3
port e4 : ACCESS PORT on UNTTAGGED Vlan 3
port g3 : TRUNK PORT with UNTTAGGED Vlan 1(default) and TAGGED Vlan 2 and Vlan 3
Configuration ESW Y:
I Use for test 2 computer with the same IP class adress.
Test Result :
Communication between ESW X e1 and ESW x e2 =>OK
Communication between ESW X e3 and ESW x e4 =>OK
Communication between ESW Y e1 and ESW Y e2 =>OK
Communication between ESW Y e3 and ESW Y e4 =>OK
Communication between ESW X e1 and ESW Y e1 or e2 =>NOK
Communication between ESW X e2 and ESW Y e1 or e2 =>NOK
Communication between ESW X e3 and ESW Y e3 or e4 =>NOK
Communication between ESW X e4 and ESW Y e3 or e4 =>NOK
Each Vlan can't communicate between the two switch, I think they're a problem in my vlan/port configuration, can you help me.
Solved! Go to Solution.
06-14-2011 07:36 AM
Hi Thibaud,
Thank you for the purchase of the ESW switches.
Just out of interest, are you using the latest firmware on your ESW switch version 2.1.19
But you sure sound like you have a great understanding of Tagged and untagged VLANs from you posting description..great stuff.
I just tried your configuration, I can communicate between ESW540-24P switch and a SF300-48P switch.
Sorry, I don't have two ESW switches handy. But it should not matter. Standards based Ethernet is hopefully just standards based ethernet
My vlan configuration below for my ESW540-24P, and it's working just fine.
I just connected switch ports 24 between the two switches together, that's why port 24 is tagged in each of the screen shots below.
I would really really doubt you would have a problem, unless there is something fundimental or basic you have done such as not saving the running configuration to the startup configuration. Obviously not backing up tjhe configuration before a power down will kill the configuration.
( saved your configuration within each switch)
Here is a copy of a section of my switch running configuration, that resulted from me playing with the ESW configuration utility.
(note that my switch has all Gigabit ethernet ports;)
interface range ethernet g(1-2)
switchport trunk native vlan 2
exit
interface ethernet g24
switchport trunk allowed vlan add 2
exit
interface range ethernet g(3-4)
switchport trunk native vlan 3
exit
switchport trunk allowed vlan add 3
exit
If you are still having issue, here is the contact URL for the Small Business Support Center, maybe a fresh set of eyes can spot the issue;
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
regards Dave
06-14-2011 07:36 AM
Hi Thibaud,
exit
exit
exit
exit
regards Dave
06-15-2011 02:56 AM
Thanks Dave,
I make the Upgrade from 2.1.16 to 2.1.19 and now the communication between the 2 switch work, I don't know why because I've maked no change from my configuration.
Now my new challenge is to a Catalyst 3750 in my network.
Regards Thibaud
